Sponsored by: Real Truck
trialer light relay
Old Jun 9, 2010 | 07:53 AM
ASMincBrian's Avatar
ASMincBrian
4wd Low
trialer light relay
04 F450 Is there a trailer light relay? Cannot get power for lights at connector. Electric brakes working. Checked all fuses. Any suggestions.
Old Jun 9, 2010 | 01:31 PM
MRUGG's Avatar
MRUGG
great question I have the exact same issue with 07.
Old Jun 9, 2010 | 02:51 PM
bpounds's Avatar
bpounds
Sounds like you both need an owners manual for your particular vehicle. In it you will find all the fuses and relays listed.
I am more familiar with the '07, but if you download the manual for the '04 you should also find the info. It won't be the same for the two models.
You have relays for the trailer lamps. For example there is a left turn relay and a right turn relay. On the '07, these will be found in a second fuse box under the hood. Each circuit will have a fuse also. Is it possible you only checked the fuses under the steering column in the cab? Look for the others under the hood.
You can download your owners manuals here:
http://www.motorcraftservice.com/vdi...d=&kevin=rules
Click on the tab for Owners Manuals on the left. Select your model and year, download it, and then look under Roadside Emergencies.
aaronlaaron
Feb 11, 2015 08:47 PM
767indian
Aug 16, 2010 09:53 PM
wrecked77
Nov 3, 2009 03:37 PM
jrouse
Dec 14, 2005 06:00 AM
BlueDolphin
Jul 31, 2005 12:28 AM
