Brake light relay question
Old Jul 30, 2005 | 04:44 AM
BlueDolphin's Avatar
BlueDolphin
I want to install a brake light relay. Where should I put it in line? Before brake switch, after, etc.?
Also is there a particular relay that I need to buy specifically for brake lights?
Old Jul 30, 2005 | 08:50 AM
51dueller's Avatar
51dueller
You would use the brake switch to trigger the relay on.
Old Jul 30, 2005 | 02:47 PM
BlueDolphin
Thanks.
So I spose I should mount as close AFTER the brake switch as I can.
Is there a particular relay that I should be using?
Old Jul 30, 2005 | 09:45 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Just curious why you want to do this? It will make turn signals almost impossible, unless you have separate bulbs for that?
Old Jul 31, 2005 | 12:28 AM
BlueDolphin
As it turns out, it looks like I won't have to do this. I was having trouble with a breaker tripping. It turned out the breaker bar was wired incorrectly. Since the fix, no problems wth the tail light/brake light functioning as it should.
I was thinking that using a relay would create a better functioning brake light.
Had not thought about the turn signal. I don't have one installed yet, but will likely be doing that in the future, so the brake light relay would not have been a good idea.
Thanks
edzeb
Jan 4, 2025 03:23 AM
Keith Free
1978 - 1996 Big Bronco
Sep 4, 2016 12:52 PM
Keith Free
Aug 31, 2016 06:34 PM
jc8825
Jul 16, 2010 02:07 PM
mtttricker
Electrical Systems/Wiring
Sep 11, 2005 06:04 PM
