vin code
Old Jun 7, 2010 | 09:15 PM
pstroker's Avatar
pstroker
vin code
I have a 2002 4.0 sohc explorer needs a motor.my exp is a vin code K the motor I purchased is a vin code E will this be an issue ??
Old Jun 7, 2010 | 10:45 PM
esaycho's Avatar
esaycho
I'm going to guess you will have a problem, your vehicle is a flex fuel motor, and the one you are putting in is a non flex fuel motor
Old Jun 8, 2010 | 04:58 AM
pstroker's Avatar
pstroker
the origional motor has timing chain issues and has swallowed a valve
Old Jun 8, 2010 | 10:46 PM
esaycho's Avatar
esaycho
What I'm saying is your probably gonna need to find a vin code K motor as that is a flex fuel motor, which your explorer is set up as a flex fuel vehicle, the vin code E motor you have purchased is a non flex fuel motor, and i'm not sure how well the computer will like that
Old Jun 9, 2010 | 06:06 AM
ncranchero's Avatar
ncranchero
Not sure but I wouldn't think the long block would be any different. All exterior items "should" swap over from the old to the new.
Old Jun 9, 2010 | 02:00 PM
pstroker's Avatar
pstroker
Whats the difference i have a complete orig motor cant be too much to swap out can anyone tell me whats different
Old Sep 12, 2011 | 11:10 AM
vipersinu2's Avatar
vipersinu2
pstoker how did you make out with your engine swap? I also put an swapped for a gas motor in my flex chassis
canyoncat
Large Truck
44
Jan 21, 2022 06:56 AM
ByersFarm
May 27, 2014 12:08 PM
MacKenzie
2004 - 2008 F150
Jan 2, 2012 05:31 PM
MANSON
Large Truck
Oct 26, 2010 11:54 AM
taskdillon
Feb 4, 2008 07:59 PM
