Not the Purge can...The vacuum canister...if your truck is pretty much unmolested you have a Vacuum canister mounted on your driverside fender..Looks like a Soup can. It is there to hold vacuum to operate your dash switchs and such..if the hose is off..or has a leak you will get a bad idle
Looks like a SOUP CAN...under your master cylinder on the driverside fender Has a vacuum line going in and out of the can. Worth a Look.......
I see. My truck was molested apparently. I don't have that feature. I do notice that the truck idles much rougher when connected to ported instead of manifold.
Ok here is a Old mech's way of finding a bad idle due to a vacuum leak Get a can of carb cleaner with the red tube...Lightly spray small amounts vacuum hoses..intake mounting carb mounting..throttle shafts. if you find a vacuum leak the engine will smooth-out..maybe speed up
