Harmonic Balancer????
Old Feb 10, 2012 | 01:24 PM
spongecop's Avatar
spongecop
Semper Fi
So as not to highjack another thread I have some questions regarding the dampner on my truck. Have owner since September last year and the vibrations at idle seem to be increasing. Recently switched to T6 oil which is the only change. Feels like its pulsing and goes away by half when I put the truck in neutral. Only reall feel it at idle but I can feel in pedels and seat.
I tend to be a little (ok alot) OCD about stuff on my truck but am concerned about the torsional vibration issue with the dampner. I'm pulling my turbo this weekend for a rebuild so now is the time to do any other stuff needed.
OEM vs. high doller aftermarket dampners?
Any thoughts are appreciated.
Old Feb 10, 2012 | 02:31 PM
duck fan's Avatar
duck fan
Because racetruck
Several guys have reported significantly reduced vibration with both the fluiddamper and ATI. Neither of them are very cheap and the internet is full of opinions on which is better than the other and why. The short version is, the ATI is lighter weight but still uses rubber so it will wear out at some point. The fluiddamper is heavier (about the same as stock though) but should last forever.
YMMV
Fluiddamper: Riffraff Diesel: FLUIDAMPR Performance Damper
ATI: 7.3L Powerstroke ATI Super Damper Harmonic Balancer 918889
Old Feb 10, 2012 | 04:37 PM
spongecop's Avatar
spongecop
Semper Fi
Probably will just go back with a stock one. This one lasted 200k anyway.
Just went out and looked at dampner. The rubber is pooched out all the way around. Not flat and even with metal. I saw where one guy replaced his cause of that. Is that really a big deal? Could that mean its beginning to fail?
Old Feb 10, 2012 | 07:32 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
i got mine off ebay for cheap like 250 or something like that but here is a link thatll save you a few bucks.....ends in 23 hours....
http://www.ebay.com/itm/720221-FLUID...sories&vxp=mtr
Old Feb 10, 2012 | 08:16 PM
Swimholm's Avatar
Swimholm
Yeah you should probably change it, its a pretty easy job. Make sure you put some silicone on the inside of the washer.
Old Feb 11, 2012 | 12:27 AM
BadDogKuzz's Avatar
BadDogKuzz
Well agree with changing your(harmonic balancer)H.B. if you feel that it is bad and doesn't look right. But I would not go back stock I seen guys that went with the Fluiddamper and see the differents in their AE readings just from the Fluiddamper. So there are many benfits to going with a Fluiddamper and you will never need another H.B. And it will help save on bearing wear too. And in my opinion it is the best H.B. on the market. Just my 2 cents.
Also if you have 200k on the motor and you are going to change the H.B. you may as well change the LPOP.
Old Feb 11, 2012 | 07:25 AM
spongecop's Avatar
spongecop
Semper Fi
That's the plan. Thx.
Enomra
Jan 29, 2013 12:20 PM
spongecop
Feb 10, 2012 03:23 PM
wharrell
6.7L Power Stroke Diesel
Oct 30, 2011 04:16 PM
bbdano
Jan 3, 2008 08:20 AM
lexasgs400
Sep 6, 2007 11:04 AM
