Dash cluster swap???
Old Jun 2, 2010 | 08:05 AM
PRL's Avatar
PRL
Looking to change my dash cluster. My truck is a '92 f250 with electronic speedo. Currently my cluster has four guages (two on each side of the speedo), I would like to put one in that has a factory tach. From what I've seen these clusters have the four guages on the left side of the speedo and the tach on the right side. I'm curious to know if this is a plug and go thing or is there any wiring that needs to be done?
Thanks
Old Jun 2, 2010 | 08:27 AM
Casey429's Avatar
Casey429
There's a tech article here on FTE. I used it when I installed my factory tach.
Installing An OEM Tachometer In A 1992-1996 F-150 Or Bronco .: Articles
It's pretty much a plug and play deal. Just make sure if your truck is gas, get a gas cluster, diesel gets a diesel cluster. Try you best to get one from a same year truck, since there are minor differences (ABS light, etc.). Mine's a '94 and I used a '93 cluster. I believe with a '92 you have to get another '92 since it only has the rear ABS.
Old Jun 2, 2010 | 05:21 PM
PRL's Avatar
PRL
cool thanks for the info, I'll start looking now
Old Jun 3, 2010 | 12:54 PM
TexasGuy001's Avatar
TexasGuy001
It is a simple swap. I swapped mine out. The compatible years are 92-93 / 94-95 / 96 by itself (OBD II).
Most if not all of our truck have RABS. The main reason for the difference in the cluster is the air bag. The first year of the air bag was 94.
Old Jun 3, 2010 | 05:18 PM
PRL's Avatar
PRL
That info will help out big time, thanks
Old Jun 3, 2010 | 07:06 PM
fishforlife2007's Avatar
fishforlife2007
i used that guide when doing the cluster swap on my truck. let us know if you have any questions man.
ps. dont forget to hookup the harness that goes to the dual tank switch, or plug if you have a single tank on the back side of the dash trim or the truck wont start...dont ask me how i know this...lol.
Old Jun 3, 2010 | 07:30 PM
Eddiec1564's Avatar
Eddiec1564
Also if you want to keep your milage and ratio programing of the PSOM(speedometer) you can switch them around. All speedo heads are the same mounting inside the clusters.
Old Jun 3, 2010 | 09:02 PM
PRL's Avatar
PRL
This is really great to get all this little info. I had no idea about the speedo, I thought the computer would take care of the milage. And the plug for the dual tank switch, I think I found that out the same way you did, lol.
Old Jun 3, 2010 | 11:29 PM
Casey429's Avatar
Casey429
I was told the Bronco I got my cluster from was a '93. Maybe it was a '94 then, or did Bronco's get airbags before F-150's?
Old Jun 4, 2010 | 12:30 AM
TexasGuy001
I believe that Broncos got air bags and 3rd brake lights in 94 as well. Maybe the Bronco you got it from was a 94. Does your air bag symbol light up when you start the truck?
The problem I have read about with getting the wrong year cluster is that the battery won't charge.
Old Jun 4, 2010 | 10:09 AM
fishforlife2007
yes the problem with the wrong years is that the pin location on the harness plug ins is slightly different. it will plug in but by having the open pins, it will create and open in your circuit and drain your battery quickly. thats why making sure your year is so important.
Old Jul 13, 2010 | 09:12 PM
Roger Carter's Avatar
Roger Carter
Looking to do this swap on my '97 F-350. Seems all the notes and hints miss my truck. My '97 is a 5.8 gas motor, has OBD-1, (confirmed) and no air bag (9300 gvw). Any ideas on what year dash cluster would work?
Thanks,
Roger Carter
Old Jul 14, 2010 | 08:12 PM
TexasGuy001
I would think that you would need a cluster from another F250 F350. Since they are all OBD I and do not have an air bag, it seems that would work. Someone please chime in if I am incorrect.
Old Jul 14, 2010 | 08:40 PM
Roger Carter
Thanks TexasGuy. Would that be a '97, or would an earlier year with OBD 1 work? From the information I gathered in the thread, it sounded like there was compatability issues, year to year.
Roger Carter
Old Jul 14, 2010 | 08:57 PM
TexasGuy001
I would think an earlier 96 or even 95 etc would work, since the trucks are almost identicle and are all OBD I. I would look for a 97 F250 F350 cluster first though.
Handegard
Feb 22, 2014 11:27 AM
stydel311
23
Nov 20, 2013 08:17 AM
xmontex4
Nov 7, 2013 03:20 PM
agryphon
1983 - 2012 Ranger & B-Series
17
Feb 23, 2006 12:03 AM
Craig5_12
16
Sep 30, 2005 07:41 AM
