yet another dumb trans question
Old Jun 5, 2010 | 09:37 PM
wickedklown83's Avatar
wickedklown83
ok i am semi-soon going to be looking at doing a trans filter and fluid change on my 1990 f250, its got the E4OD trans, i have read that there is a drain plug on the torque convertor also to drain that fluid too, is this true? (i have not yet gotten to crawl under that far and inspect everything yet or not) if so how much fluid will it take for a complete refill, and what way should it be rifilled (i.e. dump 5 quarts in, run through gears then add 4 more.. etc. etc.)
also a big question i have, is there a difference from dexron 3 mercron and type f truthfully?? if so what, and what kind would everyone recommend and where have you found best prices at.
i know the transfer case takes ATF in it also ( i actually woulda thought it woulda been gear oil, but whatever ) and was gonna drain it out and refill at the same time. can it use the same trans fluid as the tranny itself, and what is its capacity??
sorry for the long post, but i wanna have everything i need and not have to make a hundred trips to the parts store. thanks in advance
Old Jun 5, 2010 | 10:07 PM
poocher pup's Avatar
poocher pup
yes there is a drain in the torque converter, and transfer case uses the same type of fluid. prices are going to depend on where you go don't know anything about pa. would recommend buying in 1-gallon jugs or 5-gallon bucket to save some money. amounts will depend on what make and model of transfer case you have.
Old Jun 6, 2010 | 12:46 AM
wickedklown83
ok so quick question, what type of trans fluid does the E4OD take exactly, i dont have a owners manual for the truck, the dipstick doesnt say anything, and the Haynes manual tells every other type of trans BUT the E4OD, go figure lol.... to quote the manual it says c4, c6, and aod 1980 dexron II, 1981 on is MERCON, and c5 is type H, but no mention of the E4OD (also never heard of type H) im getting mixed results searching the internet, some says type F, and others Mercon V (5).. i figure somebody here has to know the correct answer
Old Jun 6, 2010 | 12:53 AM
rla2005's Avatar
rla2005
I have always used DexIII/Mercon in all my 90's vintage E4OD equipped trucks with no problems. No fancy synthetics ($$$), just plain ol' Dex/Mercon. All 15+ quarts.....
Old Jun 6, 2010 | 01:46 AM
nighthawk285's Avatar
nighthawk285
E4OD uses Dexron III/Mercon.
Old Jun 6, 2010 | 02:05 AM
wickedklown83
ok so i found a good deal on tranny fluid, but never heard of them before, and want to see what you guys think, worth using or just stick to name brands we all know?
Traveller ATF Dexron III/Mercon Transmission Fluid, 2 gal. - 0831134 | Tractor Supply Company
Old Jun 6, 2010 | 03:52 AM
Lazy K's Avatar
Lazy K
Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles Read here before you start.
As for fluid, if I had an E4OD, I would use MercronV. You will probably need 16qts of whatever fluid you choose for the trans and around another 4qts for the case.
When doing the transfer case make sure you take the fill bung out first. That way if you can`t get it out the transfer case will still have fluid in it.
Old Jun 6, 2010 | 10:13 AM
rla2005's Avatar
rla2005
The Dexron/Mercon vs. Mercon V debate has raged on for years. I'll stick with the Dex/Merc in my stock E4ODs. Anytime I have had a transmission rebuilt I use whatever the builder recommends. I have never had an issue following this philosophy. Your results may vary.
1Austin112
Sep 22, 2015 05:15 PM
pbrogan
Sep 10, 2015 05:46 PM
bmuhlbach
Escape & Escape Hybrid
Apr 26, 2015 08:12 PM
1994 f150 4x4
Sep 3, 2013 08:49 AM
e-manfive
May 12, 2004 08:08 PM
