Front End/Alignment ????
Old Jun 5, 2010 | 04:25 PM
B Big's Avatar
B Big
1995 F-350 Dually 4 Door.
The passenger tire is wearing out. I've been told it is a camber issue. This truck doesn't have an adjustable camber & I need to order a ball joint that has an adjustable camber.
Where can I get these parts?
Old Jun 7, 2010 | 06:09 PM
tbone heller's Avatar
tbone heller
The shop doing the alignment should be able to install the desired sleeve for the camber/caster. If not, don't let them align your truck.
Old Jun 7, 2010 | 09:34 PM
rn360908's Avatar
rn360908
If it just started wearing out the passenger tire then the your ball joints are probably just worn out, so just buy the best ball joints you can from your local parts store and like tbone heller said, if the allignment shop doesn't have adjustable camber bushing in stock then they shouldn't even be touching your truck.
Will Chiello
Sep 1, 2011 11:08 AM
vbxt
Jul 26, 2011 09:16 PM
twister2gt
Jun 29, 2009 09:02 AM
llehmn
Oct 6, 2005 07:54 PM
Seifferlein
Jun 29, 2003 12:53 PM
