Keep killing water pumps
Old Sep 2, 2010 | 06:54 PM
  #31
pjwoolw's Avatar
pjwoolw
It may or may not be the tensioner. Pictures would really help. Is the tensioner that longer than OEM one? If so I've always thought the replacement belts were a bit tight. In fact I won't use them at all. When I changed my tensioner to the SD type I got a Goodyear belt that was a bit longer than most. The Dayton belt I had to use temporarily was quite a bit shorter and was the correct belt according to the parts store and my research at the time. But its unlikely thats your issue. Since this has been going on for so long I say bite the bullet and replace everything including the pulley that the belt runs on. Got to be a fan, clutch and pulley in a wrecking yard somewhere. If you haven't had the truck since new there is no telling what may have happened to it.
Old Sep 2, 2010 | 07:31 PM
  #32
84-250's Avatar
84-250
pjwoolw: I have no idea the length of the OEM tensioner. Right now I have a dayco tensioner on it with 46k on it. The belt is an OEM motorcraft with 34k. The pump has 5k. The tensioner almost stays still while the engine is running but I have seen new cars where the tensioner is bouncing rapidly tho.
Im leaning toward cheap pump, cause $150 is cheap . When this one goes out, ill put in a GMB pump from napa instead of the tru-cool that I got twice. I really dont want to spend $300 to buy from Ed, but if it comes to that.
Old Sep 2, 2010 | 07:39 PM
  #33
427 fordman's Avatar
427 fordman
I by no means want to tell you what to do but if I kept having problems with water pumps like that 300 bucks (better quality I sure hope)is a lot better than to keep buying cheapos and fighting a problem. I'd bite the bullet and get a new pump from ed and a clutch too. Just my .02. Hope you get it fixed up soon.
  #34
Action4478's Avatar
Action4478
If OP was able to put the belt on without forcing it , the tensioner is not the problem ...
Old Sep 2, 2010 | 07:42 PM
  #35
pjwoolw's Avatar
pjwoolw
Thats is the OEM tensioner. The new model is about twice as long.
Old Sep 2, 2010 | 07:43 PM
  #36
pjwoolw's Avatar
pjwoolw
Just for reference Rick.
Old Sep 2, 2010 | 07:45 PM
  #37
Action4478's Avatar
Action4478
There are a lot of other bearings in play if the belt was too tight ..
Old Sep 2, 2010 | 07:55 PM
  #38
84-250's Avatar
84-250
I got the long arm tensioner. I've only bought one pump.
  #39
pjwoolw's Avatar
pjwoolw
Hard to say whats what without being there. Since the OP seems to like changing water pumps without finding the real cause..........
No offense meant.
I thought some background around the tensioner was appropriate.
Old Sep 2, 2010 | 08:12 PM
  #40
84-250's Avatar
84-250
Thanks pjwoolw, but if i knew what part was bad instead of guessing and hoping i would gladly part out my money to fix the problem.
Why dont i remove the water pump and rad, install a oil cooler inplace of the rad and be oil cooled? that would fix my problem for sure
Old Sep 2, 2010 | 08:14 PM
  #41
Action4478's Avatar
Action4478
No offense meant.
No offense taken . I figured if OP had trouble getting the belt on , he would have said so ...
Well... Did you have trouble getting the belt back on ?....
Old Sep 2, 2010 | 08:25 PM
  #42
84-250's Avatar
84-250
wasnt really difficult to change the belt.
CenFlo73PSD
Apr 18, 2017 10:22 AM
BuddyBarnes
13
Aug 24, 2016 03:49 PM
queen of spades
Oct 16, 2015 03:44 PM
barnbridge
Jul 20, 2009 07:58 PM
masterc16
Jan 28, 2007 09:40 AM
