water pump
Old Aug 21, 2016 | 08:48 AM
BuddyBarnes's Avatar
BuddyBarnes
water pump
This will make the 4th water pump I have replaced this year. Leaking from weep hole. 3 auto zone and this one napa. I have not even put the fan on yet. Good coolant, good coolant filter, not very old tensioner . only thing I can see is the pumps are all made in china. Any Ideas what is going on besides just bad pumps? 94.5 f350
Old Aug 21, 2016 | 04:36 PM
Raleigh234's Avatar
Raleigh234
Have you replaced your fan clutch? Mine went bad because of a worn fan clutch once. I was told to replace them at the same time...
Old Aug 21, 2016 | 05:44 PM
BuddyBarnes
No, I have not changed the fan clutch. On this last pump I have not run with the fan on so that would not be it. Thanks.
Old Aug 22, 2016 | 09:08 AM
oldbird1965's Avatar
oldbird1965
I was going to say get a filter but you have one. Its expensive but it will be the last one you'll have to buy:
http://www.dieselsite.com/1994-1995f...waterpump.aspx
Old Aug 22, 2016 | 09:56 AM
Airstreamer67's Avatar
Airstreamer67
I replaced my water pump a couple of years ago. The instructions with the new pump said to replace the fan clutch too. I thought it was strange to throw that bit of advice in, so I ignored it. Now I understand why they recommended it.
Old Aug 22, 2016 | 10:24 AM
oldbird1965
I personally don't think the fan clutch has any thing to do with it! Someone would have to explain to me why! I think its cheap *** china shi! for pumps being used and not a good one like in my link above.
Old Aug 22, 2016 | 11:10 AM
BBslider001's Avatar
BBslider001
I second this sentiment.
Old Aug 22, 2016 | 01:56 PM
BuddyBarnes
oldbird. What is the difference? Is it made in us? AutoZone and Napa are the same price new and made in China. Both have life time warranty but who wants to change a water pump every 3 mo. Since the fan and clutch were eliminated I can not see that being the problem . Only other thing I could think of is the tensioner but I replaced that a while back with an oem . Plus I do not think it could put that much tension on the pump. I am also thinking china junk.
Old Aug 22, 2016 | 02:12 PM
Hussler's Avatar
Hussler
I learned many years ago when replacing items such as water pump go OEM and new only. Lessons learned over the years, never go remanufactured.
Old Aug 22, 2016 | 03:16 PM
BuddyBarnes
Called ford they want $352.00. They think it is new and they do not know where it is made at.
Old Aug 22, 2016 | 03:24 PM
BuddyBarnes
Called Dieselsite on the one olddbird posted. The pump is cast in China but the internals are US.
Old Aug 24, 2016 | 02:41 PM
79jasper's Avatar
79jasper
I had the autozone one leak also. The replacement one is still leak free. (Knock on wood)
Pretty sure even the Motorcraft one is outsourced now.
I would trust the diesel site one. (Well not necessarily trust it, but trust customer service)
Old Aug 24, 2016 | 03:38 PM
BuddyBarnes
Yea, I think I will try dieselsite next too. These have life time warranty but Dang.
Old Aug 24, 2016 | 03:49 PM
79jasper's Avatar
79jasper
My next one will be the diesel site with the filter on it
brewerkz
Apr 17, 2017 09:03 PM
ReFlectiveMan
Jan 17, 2012 08:19 PM
84-250
41
Sep 2, 2010 08:25 PM
bigbrown84truck
Apr 10, 2006 09:14 PM
mark38090
Jul 20, 1999 01:59 PM
