Offroad & 4x4
loader axles
Old Jun 24, 2010 | 07:11 PM
  #31
unclejunk's Avatar
unclejunk
yeah iam sure they use f106 rears and yes they also do use zf s but zfs are way harder to get unlike f106 rocs are every where sorry for my english i speak another language flueintly not english they also put clark 20 ton planateries on the ends of a built f106 thats the custom built f106 housing built by patricks chasis you have there in the pics i will find you a link to how they convert a f106 if you want
Old Jun 24, 2010 | 07:13 PM
  #32
unclejunk's Avatar
unclejunk
Monster Highway's Monster Truck Parts List & data Sheets - Axles ...
Sep 21, 2008 ... F106, 5 ton. 6.44:1, 8.88:1 and 10.26:1. PS250 Rockwell Axle with Planetaries ... Internet solutions for The Monster Truck Racing Industry ...
Monster Highway's Monster Truck Parts List & data Sheets - Axles and Planetary Ends or Knuckles - Cached - Similar
Old Jun 24, 2010 | 07:16 PM
  #33
unclejunk's Avatar
unclejunk
high speed i like that name maybe change my user name to high speed thats great i like that name may be thats what i will call this truck high speed thats too good !!!!!!!!!!!!:
Old Jun 24, 2010 | 07:18 PM
  #34
alpha/omega's Avatar
alpha/omega
for multi-million multi-national organizations such as Bigfoot Inc do you really think "hard to find" means anything?
Do you really think any component from a JD combine is a direct bolt in on a monster truck? Do you really think Bob Chandler has hired some pimple faced little highschool dork to run to the local Napa to pick up a set of wheel bearings? Everything is custom and team specific for a vast majority of the parts.
Ive heard of F106s uses quite a bit in pulling trucks so its no doubt they are strong.
You did think outside the box with the loader axles...its just the wrong direction.
BTW...
just because a company is called "Monster Truck Parts" doesnt mean its what all the professional teams use in their comp trucks. I also believe any axle up to snuff for a professional monster truck would be out of the price range for someone to buy over the internet or build in their garage. So far all Ive seen is Sampson using F106s.
Old Jun 24, 2010 | 07:22 PM
  #35
unclejunk's Avatar
unclejunk
like i said life is no fun without a fabrication project i never said any thing about those axles being direct fit thats all fab work trust me we play around in a 60 acre junk yard fabing crazy stuff
Old Jun 24, 2010 | 07:26 PM
  #36
unclejunk's Avatar
unclejunk
keep looking more than just sampson use f106s iam telling ya i never said every monster truck uses them i said they are used in monster trucks and you wanted to say what was it oh yeah here it first off, youre dead *****ing wrong. Monster trucks DO NOT use F106s. Thats a GD school bus axle. They use custom hybrid ZFs/Mittlers using ZF shafts and something like 16.5:1 total gearing.
i told you they do
Old Jun 24, 2010 | 07:28 PM
  #37
unclejunk's Avatar
unclejunk
all i gather from your post train wreck is i was wright
Old Jun 24, 2010 | 08:35 PM
  #38
kjett's Avatar
kjett
I can tell you from 1st hand, driven the truck, know the owner fairly well, have some of his old part currently on my ranger, that the Equalizer monster truck has the ZF axles. He's not at high dollar as Bob C's outfit or even Dennis Anderson (which I know as well and race with his son!), but he's running a Patrick chassis. Oh, and Dennis ran a Patrick chassis with the ZF's as well. Make sure you get your info straight before you talk crap, Jr..
Old Jun 24, 2010 | 09:37 PM
  #39
unclejunk's Avatar
unclejunk
here we go again jr no one said anything about who uses zfs and who dosent all i said was monster trucks ran f106 rocks and they do jr say hi to adam and ryan 4 me huge fan
Old Jun 24, 2010 | 10:25 PM
  #40
unclejunk's Avatar
unclejunk
ote the drive shaft entering the Corvette rearend far above axle centerline illustrating an advantage provided by a 'Right Angle Drive' system.
As true racing Monster trucks were developed builders searched for a lighter alternative and the solution was found in a most unlikely place. Underneath big yellow school buses!
Most common school buses are equipped with 'Rockwell F106' rearends which are substantially lighter than 5 tons or Planetary axle assemblies and are available with a wide variety of gear ratios. Although they incorporate a conventional pinion arrangement the third member is plenty strong enough to handle high horsepower when combined with suitable planetary hubs and custom hardened axle shafts. And by this time racing Monster Trucks utilized lower engine placement and drop box transfer cases which reduced driveline angles anyhow.
Old Jun 24, 2010 | 10:29 PM
  #41
unclejunk's Avatar
unclejunk
MONSTER TECH heres the source of the history on monster trucking read it if you want goes over all the axles used by different monster trucks throught the years
Old Jun 25, 2010 | 08:00 AM
  #42
unclejunk's Avatar
unclejunk
did you read the link i posted it shows f106 turnd into monster truck axles this aint a comp its a info shareing hour here at fte have a good day
Old Jun 26, 2010 | 09:01 PM
  #43
kyledm18's Avatar
kyledm18
i dont get y every one is freaking out here i think loader axles would be a good idea.. yes.. they mount solid to the frame.. but just add your own suspension and go, its gonna have some great gears and be virtually indestructible in this case of mudding with the size tires he wants to run, think of how much torque a loader puts to those axles and the weight they carry daily
Old Jun 26, 2010 | 10:56 PM
  #44
crazyredneckanyhow's Avatar
crazyredneckanyhow
All i can say is
******** width="480" height="385"><param name="movie" value="http://www.youtube.com/v/vxr0hYefytg&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/vxr0hYefytg&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed>*********>
Old Jun 26, 2010 | 11:13 PM
  #45
fatdan460's Avatar
fatdan460
pump yer brakes kid, loader axles are fer teh florida gheys with too tall fhag trucks and tiny peckers
