Monkey face hood latch
Old Jun 3, 2010 | 11:42 PM
Jeff Olsen's Avatar
Jeff Olsen
Okay I am starting the mocking up of my 49 and think a PO has welded the hood latch on my truck for a quick fix. My question is does anyone have info on how the hood latch is suppose to be on the hood? I still need to learn how to post pics.
Old Jun 4, 2010 | 07:04 AM
bobj49f2's Avatar
bobj49f2
There's a couple of good pictures in this post:
https://www.ford-trucks.com/forums/7...rn-spring.html
Old Jun 4, 2010 | 08:17 PM
Jeff Olsen's Avatar
Jeff Olsen
Thanks Bob, Just to clarify. The part the coil spring is holding back is suppose to pivot correct? If so mine is welded on. I will have to fix that.
Old Jun 4, 2010 | 09:01 PM
bobj49f2's Avatar
bobj49f2
The part I think your referring to is the part that latches onto the mushroom shaped rod that comes up from the panel in front of the radiator, it should pivot.
Old Jun 5, 2010 | 12:48 AM
Jeff Olsen's Avatar
Jeff Olsen
That is it. Thanks for your help that will be my project this weekend.
Old Jun 5, 2010 | 10:39 AM
divermo's Avatar
divermo
Texan
Any suggestionson adjusting the latch. Looks like it catches but it doesn't.
Old Jun 5, 2010 | 11:12 AM
bobj49f2's Avatar
bobj49f2
The only adjustment I know of it raising and lowering the pin the comes up from the panel infront of the radiator. If the part in the hood isn't catching then it might be worn out and need repair.
Old Jun 5, 2010 | 01:08 PM
tip49's Avatar
tip49
Hijacked
lets take this one step further. My hood release mechanism hits on the inner portion of the grill, unless I engage the latch handle. It latches fine, but has rubbed off the paint, when making contact. I've been thinking of putting some sort of "softener" there to prevent this.
Tom
Old Jun 5, 2010 | 05:30 PM
bobj49f2's Avatar
bobj49f2
Tom,
Do you have the rubber bumper at the very front of the hood?
Old Jun 5, 2010 | 05:38 PM
tip49's Avatar
tip49
Bumpers
Bob;
I have all bumpers installed on the hood, and fitment is pretty good.
It makes sense that the latch lever would make contact at the rear of the grill assembly, but thought there may be a grommet or something that would prevent paint damage.
Tom
Old Jun 5, 2010 | 07:13 PM
bobj49f2's Avatar
bobj49f2
I also have all the bumpers on my hood and it has taken some paint off. I don't know if there is a way to totally prevent the paint from chipping some. These are very poor quality vehicles to start with, body panel fit didn't seem to be a major concern.
Old Jun 6, 2010 | 10:23 AM
tip49's Avatar
tip49
Improvements
Bob;
I'm going to look at some sort of grommet/covering/pad that will prevent paint damage where latch meets front end. Possibly rubber pad/heat shrink fastened to latch itself ?
Tom
