Need scanner help in Denver area
Old Jun 3, 2010 | 03:40 PM
endobear's Avatar
endobear
Towing my 28ft toy hauler to Utah for Memorial my od light started flashing about 4 hours into the trip. Stopped, turned the truck off, started it, no more flashing. On the way home same thing except it started flashing sooner and would only stay off a short amount of time after restarting it.
Ive been running around town now for about 200 miles unloaded and no flashing od light but it feels like its searchig for the right gear at times and just the right rpm.
Are the codes in the computer if the lights not flashing?
Any members got a scanner in the Denver area?
Old Jun 3, 2010 | 05:29 PM
F350-6's Avatar
F350-6
If the light was on, the codes should be stored.
Lot's of Colorado folks around. We'll have to wait for them to see this.
Old Jun 3, 2010 | 07:58 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
I don't have a scanner, but mine did the same thing a few months after I bough it. For me, it was a failed/failing VSS sensor on top of the rear differential. It took about 10 minutes to replace and has been working great ever since (and that was 3+ years ago).
Old Jun 3, 2010 | 11:56 PM
BillyBob69's Avatar
BillyBob69
I dont remember his FTE name but I emailed one of the long time members with a link to this thread. He is in the Parker area and has the AE program. (I think thats what its called).
Hang in there!
Old Jun 4, 2010 | 07:14 AM
Ponyboychris's Avatar
Ponyboychris
Does your speedo act funny also? As in not show any reading until you hit about 40MPH? That is also an indication that your VSS on the rear pumpkin is bad.
Sorry, don't have an AE. Andrew (87 F150 I6) has one but he hasn't been on FTE for a while. He's been working lots of hours. I'll try to reach him.
Old Jun 4, 2010 | 09:35 AM
Pocket's Avatar
Pocket
If I was in Colorado right now I would help. Unfortunately I'm in Houston right now for a funeral this weekend.
If you still need help next week, let me know.
Old Jun 4, 2010 | 10:02 AM
Ponyboychris
I forgot you have one too, Curtis. DUH!
But being in Houston doesn't help matters anyway now does it?
Old Jun 4, 2010 | 10:41 AM
van_350sd's Avatar
van_350sd
Almost any Auto Parts Shop will let you borrow the "In - House" Scanner to check your Rig in the Parking Lot.
My local Auto Zone, Advanced Auto, NAPA, and other Shops let customers use the scanner when they get codes.
Call your local Shops and ask them if you can scan your truck at their location.
Best,
Russ
Old Jun 4, 2010 | 10:47 AM
Ponyboychris
The chain auto parts store scanners are not compliant with the PSD engines installed in our trucks.
Old Jun 4, 2010 | 10:58 AM
van_350sd's Avatar
van_350sd
OK Chris,
Down here they have the expensive units opened as a display/demo and they work on the PSD's. I'm sure every area is different.
Best,
Russ
Old Jun 4, 2010 | 05:26 PM
endobear's Avatar
endobear
Thanxs for the replies.
Speedo seems normal.
