Post Swap Problems/Questions
Old Jun 3, 2010 | 10:22 AM
redman84's Avatar
redman84
I decided to start a different thread that is question specific. After the tranny swap my truck is not cranking with the key, my cruise control does not work, and my 4wd dash lights do not work either. I can start it by bridging the starter solenoid and it drives great but no CC. I used the PCM and trans harness from the donor truck. Any ideas?
Old Jun 3, 2010 | 10:34 AM
DRRXR's Avatar
DRRXR
IS the CC hooked into the clutch pedal?
Old Jun 3, 2010 | 10:55 AM
redman84's Avatar
redman84
The only thing hooked into the clutch pedal is the clutch master cylinder at least until I get a clutch activated neutral safety switch.
Old Jun 3, 2010 | 11:36 AM
DRRXR's Avatar
DRRXR
You need a CPP Switch for the CC to work.
Here is another related thread.
https://www.ford-trucks.com/forums/9...ntrol-fix.html
Check out the diagrams that Jim posted.
Old Jun 3, 2010 | 11:46 AM
redman84's Avatar
redman84
Is a clutch pedal position switch what goes onto the clutch master cylinder rod? Has it been shown to resolve the cruise issue? And what is BPA? Also, I did not swap speedo sensors from the rear end of the donor. Do I need to do that or is my original speed sensor fine?
Old Jun 3, 2010 | 06:26 PM
redman84's Avatar
redman84
Bump. Alright, I got a clutch pedal position switch but it still won't crank with the key and I don't know about cruise because I haven't cranked it. Still looking for ideas...
Old Jun 3, 2010 | 07:27 PM
Hussler's Avatar
Hussler
Is it adjusted correctly?
With the clutch out the switch should be actuated.
Try this, the plug the switch plugs into short out the pinss with something then making sure the transmission is in neutral see if it will crank. Any yes the cruse control uses the same switch for panic stop situations.
Old Jun 3, 2010 | 07:34 PM
redman84's Avatar
redman84
I see that a lot of people are looking at this thread so I'll continue brainstorming on here until the right person drops by. I have some more info that may be useful to troubleshoot this. I took from the donor all that I felt I needed. The t case was a BW 1356 and mine had a BW 4407 so I put the 4407 back in behind the ZF S5 42 that I had built so it is NOT the ZF from the donor.
As previously said, the PCM and tranny wires are from the 95 donor so really the only thing that is left from my original rig is the BW 4407 t case.
Now to the point. I'm getting no response from the key even with the clutch pedal position switch in but it runs great in all 5 gears once started. I didn't have cruise but haven't checked it since placing the CPP.
My t case only gives me 2H and neutral and no 4x4 or 4x4 lights but maybe this is due to the length of the linkage from shifter to t case. I guess even the wires could be different for a 4407 vs 1356 but it has the exact same plug. However, it really doesn't appear other than a beefier case that the 4407 is different than the 1356.
That's all I have for now. If you have any ideas even if not concrete PLEASE drop a line.
Old Jun 4, 2010 | 06:43 AM
Cuda_jim's Avatar
Cuda_jim
Here's a trouble shooting guide and electric diagram.
You may want to start at 'PINPOINT TEST B'.
Old Jun 4, 2010 | 08:14 AM
redman84's Avatar
redman84
Sounds good. I get home from work tomorrow morning and will try that. I guess it's adjusted correctly. I put it on the only way I see that it fits...
Thanks man. I think that will help me start to troubleshoot this thing. I also need to check my tranny wiring harness but the activation of my reverse lights make me think it is fine. Either way when I get ahold of a multimeter I'll be checking continuity of all the wires to rule that out as a problem.
Jake65
Nov 27, 2014 08:46 PM
X1Lightning
Apr 2, 2014 03:28 PM
Sprout22
Nov 21, 2011 08:54 PM
maxwell2425
Nov 9, 2011 06:26 PM
7.3PSD
Apr 5, 2008 09:29 AM
