Report your MPGs
Old Jun 2, 2010 | 10:34 AM
Bbasso's Avatar
Bbasso
Thumbs up Report your MPGs
describe your van.
describe the driving.
And report miles per gallon.
I'll start...
2000 E350 PSD Extended. 265/75-16, all stock with straight pipe exhaust.
last week- highway run from NY to SC within 1-3mph of speed limit with cruise control.
22.3 MPG.
Old Jun 2, 2010 | 06:45 PM
rebocardo's Avatar
rebocardo
86 4x4 351w/c-6/4.10
7 mpg city driving hubs locked
9.5-9.9 mixed unlocked hubs
11 mpg highway towing a car trailer with a B2 on it.
Old Jun 2, 2010 | 07:41 PM
maples01's Avatar
maples01
99 E-350 5.4 V-8 15 pass with only one rear bench seat, side door wheelchair lift.
245/75 R-16 E
Flowmaster Dual cat back 24" x 3 1/2" SS tips
Restriction free intake with stock box and K&N filter
Super Chip Microtuner premium gas
9-10 MPG city 13-15 MPG HWY
Knoxville to Fl it got 17 MPG once 70 MPH, never repeated it.
Old Jun 2, 2010 | 08:40 PM
senty8's Avatar
senty8
1978 E150 124"WB window van, standard column shift, 300CID engine, Carter 1bbl carb, two factory-option front captain's chairs, and a high output heater. Empty in back except for basic paneling, insulation and 1/2" plywood floor.
When the highway speed limit was still 55mph and with the original L78x15 tires, 22-23mpg.
With 235/75x15 tires, 21-22 highway mpg while the speed limit was still 55.
With 235/75x15 tires at the current 65mph speed limit, 19 highway mpg max.
City mpg from day one has always been between 13-15mpg.
Old Jun 2, 2010 | 09:19 PM
YoGeorge's Avatar
YoGeorge
Originally Posted by Bbasso
describe your van.
I'll start...
22.3 MPG.
We've had mileage threads before, but here goes: 2002 E150, 4.6, stock 3.55 rear axle and always had Michelin LTX M/S tires on it (factory and replacement set). Mild d'Elegant conversion with factory glass, low roof. Looks like a Club Wagon. No roof racks.
Mileage for 82,000 miles = 16.18 mpg. This is every gallon of gas ever put into the van since new.
Some freeway runs at over 18 if speed is kept down. Typically lightly loaded (we're bicyclists and my son is a bike racer). City mileage, especially in the winter, can be 13-14. We've had 4 big vans in the family (one after another) since 1986 and this is the best van for gas mileage we've ever had.
George
ps I also bought a '78 F100 new, back in 1978, with 300 inch six, 4 speed O/D manual trans, and a 2.75 axle. Very weak kneed but it would routinely get 20-22 mpg on the road, with a best single run of 25+ from Detroit to Cleveland and back...in the days of the 55 mph speed limit. It would have been a lot lighter than Senty8's van, though, and was a short bed stepside.
Old Jun 2, 2010 | 10:05 PM
E350Bus's Avatar
E350Bus
Driving a 1993 E350 15 passenger with 351 and 3.54 rear axle...
If memory serves correctly about 14 or so mostly highway and when towing pop-up camper and loaded with gear around 9 to 11 mpg.
Old Jun 2, 2010 | 10:49 PM
maples01's Avatar
maples01
Yeah I have 3:50 gears, I want 4:10 to increase the city mileage, heavy van needs lower gears to aid in getting it moving.
Old Jun 4, 2010 | 10:58 AM
Eddiec1564's Avatar
Eddiec1564
I get 8.6mpg average for my 95 E350 bus. 460/e4od 4.10 rear. Best I got once was 9.8mpg while tooling around Key West where speeds are never over 45mph. The worst was around 5.5mpg with some rotten gas once. Never went to that gas station again!
Old Jun 4, 2010 | 02:45 PM
wizzy214's Avatar
wizzy214
1982 E100 shorty , 300CID engine, Carter 1bbl carb, and a high output heater. hauling 2 dirtbikes and campin gear for 2.
stock motor, 7ft of 3 inch exhaust pipe where the cat and the muffler used to be.
55-60 mph the whole way and with 235/75x15 tires, 18-19 hwy
City mpg from day one has always been between 14-15mpg.
Old Jun 7, 2010 | 04:52 AM
neil 95 e350's Avatar
neil 95 e350
1995 E-350 extended van w/ 460 & E4OD (please pardon the long post but it does seem relevant):
Thorley tri-y headers(wrapped)>3.5"collector to cat>cut cat - 3.5"in/3"out>Flowmaster 70 > 3" to end, 65mm dual throttle body, ported/matched upper manifold, MSD 6a, MSD coil, water/alc inj, 4" custom intake plumbing from UMP air filter > TB, dual 200A alt, Excursion al rad, 2x16" 3k cfm fans + 3x9 1.2k cfm fans (all electric) Edelbrock H2O pump mod'ed for '95 belt drive, E350 Diesel header tank, E4OD by ATO Transmission, thermostatically controlled remote oil cooler w/ elec fan w/dual oil filters + remote trans cooler w/ elec fan and remote filter (all mounted to frame rails so not in front of radiator), Dana60 w/ Trac-Loc and stock gearing 3.7, rear disc brake conversion, front disc brake upgrade (16" rotors), large addco swaybars, bilstein shocks, poly suspension bushings, 20" wheels - 10"wide rear/8" wide front, airdam, Class V hitch. oil/trans/water temp on pillar, vacuum/wide band O2 gauges top center of dash, voltmeter for #2 charging sys on column. interior redone w/ 4 single seats and only the 4 pass bench seat (moved fwd for more storage behind). plus ~7kw audio + video system.
fwy: around 16mpg, towing 14mpg (fwy speed gen 75-80+, towing or not)
in town: 10mpg (can't control right foot)
when purchased new 12/10
Old Jun 7, 2010 | 07:15 AM
leardvr's Avatar
leardvr
1992 E350 7.5L 4.10 138WB
Stock interior. Stock powertrain. Stock motor. Stock exhaust (except CAT is gone, not sure where that went)
OH-FL 2x yr OH-AL 2x yr me driving at 70mph 12.2, my wife driving 80+ 10.8
Around town 9.5ish
Never checked towing 7400 lbs, hurts to much. I really want a PSD
Old Jun 7, 2010 | 02:11 PM
Eddiec1564's Avatar
Eddiec1564
Got photos of your setup Neil? Do you have a 2nd alternator mounted? May try some of your mods to see if I can get my beast better MPG's
Old Jun 7, 2010 | 03:24 PM
gearloose1's Avatar
gearloose1
6.0 2005 E350, roughly 1,000lbs payload.
@ 65-70mph, roughly 20mpg with summer diesel.
Old Jun 7, 2010 | 08:02 PM
Grems4ever's Avatar
Grems4ever
245/75 R-16 E
Wow...
About the same mileage as my van:
'99 E350 6.8L V-10 15 passenger
9-10 around town; 14-15 highway; 8 towing
I got 16.3 once running totally empty and towing a very light utility trailer. I'm itching to see what the new coil packs will do for the towing mpg.
Old Jun 7, 2010 | 09:31 PM
maples01's Avatar
maples01
New plugs at 97,000 was no effect good or bad, I gotta get to modifying my 73 and start driving it.
