Code reader & extension cable
Old Jun 1, 2010 | 07:02 PM
slhf150's Avatar
slhf150
I'm about to buy this code reader:
Equus 3145 - Digital Code Reader | O'Reilly Auto Parts
But reading the manual, it seems pretty much like to use it I also need an extension cable. (not included)
Anybody got a part number or link for the extension cable?
Old Jun 1, 2010 | 07:09 PM
slhf150's Avatar
slhf150
Never mind. Gooooooogle is a wonderful thing. Found the cable and the tester at a better price at Amazon.
Amazon.com: Ford Code Reader Extension Cable for EPI3145: Automotive
Old Jun 1, 2010 | 07:24 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
I have the same code reader, its a good piece of equipment. The extension cable is a waste of money, you can perform the WOT test by pulling the throttle open under the hood.
Old Jun 1, 2010 | 09:29 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Equus Innova 3145 OBD-I Ford Scan Tool
Old Jun 2, 2010 | 12:01 AM
slhf150's Avatar
slhf150
You're right. I way overstated it. Should have said "looks nice and convenient for an amateur like me to have the longer cable."
Old Jun 2, 2010 | 12:28 AM
ymeski56's Avatar
ymeski56
Der Postmeister
It's a luxury, & I deserve it (I think). Although in the 4 years I've used my #3145, I've yet to order the darn thing. With my attention span, I'd probably slam the hood down & sever the dang thing!
Old Jun 2, 2010 | 02:45 AM
BigSix1's Avatar
BigSix1
Any other opinions on whether the cable is a "must have" or a "nice to have?" Is it only useful on the WOT test? Because I seem to remember some tests that required stepping on the brake, turning the steering, etc.... (It was like rubbing your belly and patting your head at the same time, with an old flash-type scan tool I had.)
Old Jun 2, 2010 | 09:13 AM
ymeski56's Avatar
ymeski56
Der Postmeister
You hit all the high points! So to expound on your analogy, w/ the cable, you can sit comfy behind your steering wheel, while your rubbing your tummy, it will pat you on your head!!!
Old Jun 3, 2010 | 01:07 PM
TexasGuy001's Avatar
TexasGuy001
I used mine without the extension cable, but that does look handy. I may get that too.
Old Jun 4, 2010 | 08:52 PM
ClaytonSmith's Avatar
ClaytonSmith
I have a 1992 F250 with a 7.3 IDI. I have a faulty tachometer. Can I use a code reader like this and if so, where does it plug in?
Old Jun 4, 2010 | 10:05 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Ford Fuel Injection How To Run a Self-Test
Old Jun 5, 2010 | 07:46 AM
subford's Avatar
subford
I have the extension cable but only use it on my F53 so I do not have to stand on my head. I do not use it with the F & E series I have.
Even with the reader hooked up you can watch the MIL on the dash to know when to do the WOT, hit the Brake, turn the wheel and push the button.
Old Jun 5, 2010 | 09:47 PM
ClaytonSmith
I didn't see anything on reading codes with the diesel engine. Are you sure I can read codes on a '92 7.3L?
Old Jun 5, 2010 | 10:36 PM
subford's Avatar
subford
No you can not use the code reader on your truck as it has no plug for the Transmission Controller and you only have this Transmission Controller if you have a E4OD Transmission.
Old Jun 7, 2010 | 04:11 AM
TexasGuy001
Thanks for the tip. I may save my $ for something else then.
lanthony2020
Modular V10 (6.8l)
Apr 27, 2015 08:41 PM
Stikky_Nuttz
Computer Chips & Tuners
Mar 12, 2015 11:52 AM
mu2bdriver
Jan 5, 2014 07:36 PM
Cowboy65
Sep 8, 2013 12:12 AM
riverrat41
Sep 21, 2010 05:57 PM
