Pushrod preferences
Old May 30, 2010 | 11:23 PM
Richards73's Avatar
Richards73
Pushrod preferences
I am goin to replace my pushrods on my 73 390 its all stock and was wondering were yall have got pushrods from and what brands u like. Since its stock should i stay with stock pushrods or go with performance? any help and opinions would be much apperciated.
Old May 30, 2010 | 11:42 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
If you're staying bone stock then stock will suit you just fine.
For Performance TREND or Smith Brothers.
Survival Motorsports Home Page can hook you up.
Josh
Old May 31, 2010 | 12:34 AM
mark a.'s Avatar
mark a.
Why would they need replaced ?
Old May 31, 2010 | 11:15 PM
Richards73's Avatar
Richards73
my pushrods r bent. not sure y yet but gonna do some things to see y? Does any one no if i buy them from o reillys be fine or r the y no good?
thanks for the site as well
Old May 31, 2010 | 11:30 PM
Tees77f150's Avatar
Tees77f150
Yeah, that will be fine, they will work well for you.
Old May 31, 2010 | 11:39 PM
30over's Avatar
30over
If you had a 460 I could fix you right up. I have 2 sets of 5/16" Comp Cams steel "stock" push rods. 1 set is standard length and the other is the 60 thousandths longer ones.
I just went to roller rockers, guide plates and 3/8" push rods. The Comp Cams steel push rods are pretty reasonable. Seems like there about $25 from Summit. You might check it out.
Old Jun 1, 2010 | 12:32 AM
Richards73's Avatar
Richards73
ok thanks guys
Old Jun 1, 2010 | 09:21 AM
mark a.'s Avatar
mark a.
I'd find out just why before replacing them, cause if it happened once it will probably happen again.
Old Jun 3, 2010 | 02:04 AM
Richards73's Avatar
Richards73
yeah i no but i think i have figaured out y
