Problem With Smog Test
Old Jun 13, 2010 | 09:25 AM
dsquared's Avatar
dsquared
Originally Posted by Ponyboychris
Don, you might want to post up the location of that smog sniffer center. There's a couple of members in the Inland Empire area that will thank you later!
Advance Auto Smog Check Center
775 W. Foothill Blvd. (N/E corner of Foothill & San Antonio Ave)
Upland
Old Jun 13, 2010 | 09:46 AM
overthehillbill's Avatar
overthehillbill
Originally Posted by dsquared
I got my renewal notice Friday, with the dreaded "Smog certification" note. I've been taking all my vehicles to a "Test-Only" station for years now, so that's where I went yesterday. He hooked the OBD scanner to my Ex, and it died. Started back up, checked all applicable parameters, and the Ex passed!! The tech knew about the exemption for air and exhaust, and double checked the manual for my EX; CCV only, no CAT!!! I even left my F5 on, set to stock. No problems at all (Thanks Jody & Diane!!). $51.20 for test, certificate, and electronic transmittal. Now to spend the $200.00 for renewal.....
Don: Ditto with my 2001 F250 only charged $48.00. I guess lower rent in the Central Valley. BTW I see you are in Ontario. I was raised there, left when I joined the Navy and never been back.
Bill, Chaffee class of '57
Old Jun 13, 2010 | 09:55 AM
jwhitetail's Avatar
jwhitetail
I might be wrong but some scanners should not be plugged up to the OB port while the motor is running.
Old Sep 19, 2010 | 10:46 AM
sdlugatch's Avatar
sdlugatch
Do you know if the obd test is not required for f250 superduty in California, couldn't pass smog test, no data from obd test for oxygen sensors.
Old Sep 19, 2010 | 11:18 AM
Duzitall's Avatar
Duzitall
I believe the OBD test is required for Superdutys. Do any PSD Superduty's have oxygen sensors? Mine didn't come with a catalytic converter so I have no oxygen sensor.
Old Sep 19, 2010 | 11:55 AM
mongo75's Avatar
mongo75
Yeah, I might take the trip from the OC to a diesel friendly shop! I do have the smog tune from Jody though, but if I drop in a set of Stage II's I don't know if it'll be clear enough....
Old Sep 19, 2010 | 02:57 PM
Bonanza35's Avatar
Bonanza35
Just took mine in yesterday9-18. I was not looking forward to this. Took the wifes car first. Asked the tech about my psd cc and told him it was stock with new trans and a tuner. I have a DP tune on the pod. I left it in stock he did his thing as I watched and read the paper, it passed in flying colors. This was a state smog only station here in Norco. After reading everybody's night mares I have been puting this off and it was due by end of the month. It just depends on the shop I guess and if you have a cat or not.
Old Sep 19, 2010 | 04:30 PM
SpringerPop's Avatar
SpringerPop
On the same decal on the valve cover which tells the tech what emissions equipment must be present and operational, it says "This engine is OBD-II Exempt".
This means that they may not be able to read any or all of the OBD-II information.
Ask the tech what HE thinks "Exempt" means.
This is sure turning into a fiasco for some of you, and it usually happens at a smog station that has less-than-competent technicians. If they are really sharp, they'll catch you if you're cheating (which they should), but they also KNOW the rules, and if you pass, you pass.
Pop
Old Sep 19, 2010 | 04:46 PM
Duzitall's Avatar
Duzitall
Pop
Fiasco yes, OBD-II exempt no. My 2002 California, automatic trans is clearly labeled "California and Federal EPA compliant. OBD-II certified. NON- CATALYST"
Old Sep 20, 2010 | 12:05 AM
chiefn10's Avatar
chiefn10
took my wife's 250 in last week to get smog tested. mechanic first said he needed to verify that everything was stock because the test won't pass if there is an aftermarket air filter or exhaust. thought it was the stupidest thing i have heard.
Luckily, my 350 dually is registered in Texas and doesn't require a smog test dince i have the 6637 filter and running 5" stacks.
Old Sep 20, 2010 | 12:37 AM
Stewart_H's Avatar
Stewart_H
Originally Posted by chiefn10
...because the test won't pass if there is an aftermarket air filter or exhaust. thought it was the stupidest thing i have heard.
It is stupid. That tech doesn't know jack-squat about smogging a diesel.
All aftermarket air filters and exhaust systems have been cleared by BAR as being CARB compliant.
Stewart
Old Sep 20, 2010 | 05:19 AM
megawatt00's Avatar
megawatt00
You should be ok Danny I have to smog check here in MA and my singles in Jodys stock tune I passed with flying colors.
Old Sep 20, 2010 | 10:08 AM
  #28
timmyboy76's Avatar
timmyboy76
Temecula
Temecula Smog (test only) for me...Winchester/Ynez streets. Purchased truck, a month ago, had to get ur smogged, but fortuntly, the seller, previously owned Temecula Smog, so the truck wasnt new to them. The tech had issue with scanner, killing the motor when testing, but figured it out. Completely stock, at the time......just throw'n it out there.
UNTAMND
Feb 9, 2016 07:06 PM
WRD1966
Sep 26, 2015 08:27 PM
Titanic15
1978 - 1996 Big Bronco
Jan 5, 2014 08:41 PM
vls
13
Dec 11, 2011 05:34 PM
