Second question of the night...sorry to hog!
2000/F350/7.3L/4X4/Auto
My oil dip stick has always been tough to get back in taking way more effort than it should but recently it takes me getting under the hood and feeding it in with two hands at an inch at a time...and at 3' long checking the oil has turned into as seldom as possible.
Sounds to me like the tube is either bent or clogged. I would recommend that you take it off (only have to remove 1 nut). Visually inspect the tube. If it is not kinked, use some brake cleaner to clean it out. It might take running the dipstick in and out with the brake cleaner in it several times to get it clean. Be sure to get a new o-ring for the bottom, because the old one will never seal again.
GARY GORE
04-08-2014 09:21 PM
