here is a trick i learned to take off an oil filter in a 86 302. take a large peaches can (4" x 4 3/4 ,cut out the bottom(so you now have a pipe) loosen the filter, slide the can over it until it contacts the engine.your filter will stick out the end of the can enough to get a grip and take it off. all the oil will run down the inside of the can and thru the large hole in the crossmember,and into your drain pan.
you can add to someones reputation status (those green lighted dots) by clicking that icon second from the top right on their post.
Feel free to try it on me.
