Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Coolant System Guides
- How to Flush Radiator
Step by step instructions for do-it-yourself repairs
Gooch's Radiator/Engine Backflush Procedure and Coolant Information
#422
Man its hard to impossible to find name brand coolant concentrate anywhere. I even tried a NAPA Truck Parts store and they only had 50/50 mixes. They sent me to Fleetpride. Had never heard of it until today, and I found the last 4 gallons of Fleetpride's house brand, OTR (Over the Road) ethylene glycol based concentrate.
Anyone ever heard of this brand?
#423
No sir, I have not.
Tractor Supply Company (TSC) has Rotella ELC concentrate bottles by the gallon on the shelf or online.
That is where I bought my ELC from when I changed over after a Caterpillar location sold me some ELC blend stuff. I returned it and left the store because they insisted I did not need 4 gallons of concentrate ELC for my 7.3L Ford.
#424
#426
#427
#428
#429
This is some high quality info from a real pro. Gotta love it when the pro's speak up.
One question and I believe its self answering --- run the heater when doing the flush - I would expect that would be a YES and should be added to the original instructions?
Thank you Gooch and friends.
So so no it is not necessary.
#430
#432
#433
If you've got a truck without the vacuum-operated shut-off valve, feel free to mod yours by adding one.
Or, a simple ball valve in one of the the heater core hoses, manually operated as the seasons dictate, works just as well.
Air conditioning system will run a bit cooler for your effort.
Pop
Pop
#434
Ive been idling my truck for an hour and still the Motorcraft RT1201 Thermostat isn't opening. It's 75 F outside. It's a mechanical thermostat , so Iikely just need to keep it at 2000 rpm until it opens, but to add to the confusion it looks like I received a faulty Motocraft coolant sender from Riff Raff Diesel. They sent me the black colored F65Z10884AA https://www.riffraffdiesel.com/coola...-sensor-99-03/ and it seems it isn't working. The wiring harness to the sensor looks fine.
With this black sensor installed into the water pump, the temp gauge reads zero or red hot at the dashboard, even when the engine is cold and CHECK GAUGE light comes on on the dash.
So far I have added 4 gallons of coolant concentrate and 1 gallon distilled water. EDIT: ended up getting 4 gallons of concentrate and 2 gallons of distilled water after driving around the city for an hour. There must be 2 gallons trapped in their which are "undrainable".
Should i wait for the motor to cool off and switch the old temp sensor in or ignore the temp gauge and keep her running until she accepts the remaining distilled water?
I also installed new water pump and oil cooler plus the vastly over priced, but lovely blue-colored, Sinister Diesel coolant filtration system.
I am getting heat is the cabin.
If I plug the old light grey colored coolant temp sensor in and let it dangle, the dashboard gauge goes up 1/8 slowly (its getting hot touching the HPOP oil reservoir) and the dashboard doesn't indicate CHECK GAUGE. Torque app reads No Data for both new sensor, installed and sensor just dangling but plugged in. EDIT: I took out the black water temp sensor RiffRaff sold me and put the old gray one back, gusher of coolant included!, and now the temp gauge reads normally
I count on RiffRaff to sell me the correct parts. Maybe this one is faulty or could there be more than one coolant temp sensor???
#435
