Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Coolant System Guides
- How to Flush Radiator
Step by step instructions for do-it-yourself repairs
Gooch's Radiator/Engine Backflush Procedure and Coolant Information
#481
I don't know what to say. I just called the parts department both times. They said pre 2001 may be a problem but they will give it a whack. Both gave the same date so I assume they are right. Trust but verify
#482
So, I read through all of the initial information here, and a bunch of comments but gave up reading somewhere around the page seven mark. I have a 96 7.3 and I need to do a coolant flush. My preference would be to run an ELC, probably not surprising. In the next year or so I plan to upgrade/replace my injectors and replace the injector cups. Aside from different injector cups, is there anything else I really should do to switch to an ELC? Or is it to the point where I might as well pull an L99-03 motor and put it in my truck if I want to run ELC? Thank you for any advice!
#483
#485
Pretty sure this is what you're looking for
https://www.riffraffdiesel.com/injec...ning-compound/
Edit: little more info
https://www.ford-trucks.com/forums/1...p-sealant.html
#486
Nice write up and recommendations for flushing.
Those 1/4 inch plugs were a pain to get out.... took some patience and PB blaster.
Question.
After the hose flush why not use some light compressed air to blow any left over water out of the system?
Like 10-12 psi just like blowing out a sprinkler or pool line for winter.
Question.
#487
E99 elc to precharge
Hi guys. It’s been a very long time since I have been active on here but I just saved an e99 from the junk yard. Before I realized it was an e99 I did gooch’s flush and put in red elc fleet charge. I had a clamp failure and lost all of my coolant. After reading the possible issues with elc and the e99 I am thinking about switching to a pre charged coolant (fleet charge) since I just lost most of my elc. Also I am going to switch my coolant filter to a sca charged Hastings filter.
should I flush a few time with distilled to get all of the elc out before I switch to a pre charged? I am assuming so, but just wanted to be sure.
thanks in advance!
thanks in advance!
#488
You’ll want to remove the block drains and take the return hose off the water pump. Pour distilled water through heater core to rinse it out.
I don’t think filling system with distilled water again is needed, but it won’t hurt if you do.
If you perviously used the hose to fully FLUSH the cooling system until it was CLEAN, you’re set.
You do not want a pre-charged filter with pre-charged coolant. One or the other.
#490
#491
I have an e99 which I replaced the injector cups using the Loctite 620 sealant. Actually, I replaced them twice because I didn't know about the proper way to torque the injector hold down bolts.
Degas bottle, WP, WP outlet pipe, t-stat and all hoses have been replaced.
I researched the subject fairly thoroughly and purchased 4 gallons of Rotella ELC, 20+ gallons of distilled water and a flush tee.
I'm getting ready to flush and swap to the Rotella ELC and just wanted to see what the latest opinions are on using ELC in an e99 after replacing cups and using Loctite 620.
I realize this thread is 11 years old, so there should be plenty of e99 owners like myself who have done the swap and should have some history as for the compatibility.
Thank you!
Thank you!
#492
Thank you!
Thank you!
The following users liked this post:
#494
#495
Here is what Gooch has to say about using tap water, versus distilled water, in our engines.
The following information was compiled from several posts in a single thread, by Gooch.
Even some of the best tap water will contain undesirable minerals, dissolved salts, and acids. Those components, like calcium, iron, magnesium, carbonates, hydroxides, nitrates, and so on, not only reduce the life of the coolant, but they reduce its ability to protect the cooling system. Those of us experienced with cooling systems know that tap water undoubtedly leads to exacerbated cooling system failures.
Since tap water is not pH neutral, it changes the desired alkalinity of the coolant formulation when mixed with the coolant. Distilled water, although not always completely mineral-free, is generally more neutral than reverse osmosis and purified water.
By using proper cooling system maintenance, you won't need to worry about having your radiator rodded or replaced.
You could flush with tap water, as long as your tap water was exceptional. Otherwise it is best to make your final flush(es) with distilled water. Always fill with distilled water.
It doesn't matter what conditions you operate your vehicle under. Coolant with distilled water will always protect your cooling system better and longer than tap water.
Using tap water for coolant maintenance...is second-rate maintenance. That is not opinion, but a well-known fact.
Where coolants are concerned, the facts are the facts. Using tap water will have consequences down the road...reduced protection, reduced coolant life, increased maintenance, and premature repair. Using tap water is sloppy, second-rate work.
Stewart
Stewart
