1978 - 1996 Big Bronco
is it just mine?
Old Feb 3, 2003 | 04:12 PM
treehugger36's Avatar
treehugger36
is it just mine?
Or do all broncos have a REALLY stiff suspension? I feel EVER tiny bump on the road! I am sick of not being able to play CDs and I want a softer suspension. Is there anything I can do? is there somewhere I can get new springs for the front, or is this a shock problem?
Old Feb 3, 2003 | 04:43 PM
DeKuma's Avatar
DeKuma
is it just mine?
Mine is pretty damn stiff as well.
Between my rough country shocks and 33" Wild country EXTs it feels every pebble. The nice thing is though, I get almost no body lean in a corner. It drives like it is on rails.
Old Feb 3, 2003 | 05:27 PM
dsickles's Avatar
dsickles
is it just mine?
mines not that bad at all ive been on explorers that have been worse. it may depend on the year though.
Old Feb 3, 2003 | 06:01 PM
mrwizard's Avatar
mrwizard
is it just mine?
My solution was to buy a CD player with a 10 second anti-shock memory.
I was considering buying a kidney belt to help with mine after I put on a set of Rancho RS5000's. I was very surprised when my BFG All-Terrains wore out and I put on a set of Michelins how much the ride improved. It was quite dramatic.
Old Feb 3, 2003 | 06:28 PM
bronco351's Avatar
bronco351
is it just mine?
That's not a spring or shock problem. The problem is you probably have after-market shocks that are set to be stiff. If the shocks or springs had a problem, the ride woul dbe so soft you would bounce 20 times if you move in your seat!!!
Old Feb 3, 2003 | 08:16 PM
greystreak92's Avatar
greystreak92
is it just mine?
An older set of springs will more likely be "mushy" than stiff. If they are new or the truck has been lifted via new springs, then you may be looking at a spring-related concern. If none of these things have been implemented, I would lean towards shocks or just worn suspension components. Worn bushings or dying shocks can have the effect of amplifying potholes, bumps etc..
Old Feb 3, 2003 | 10:42 PM
treehugger36
is it just mine?
Unfortunately my bronc has no suspension lift and what not, I wish it did.
I for one love the cushy suspension. Not so much the bad shocks suspension but rather the Desert racing Trophy truck suspension.
so I should check my shocks and see if they are adjustable?
Old Feb 5, 2003 | 07:17 AM
steve83's Avatar
steve83
is it just mine?
I added about 1000lb of cargo & mods to mine, and it's pretty soft...
Old Feb 5, 2003 | 03:49 PM
JBronco's Avatar
JBronco
is it just mine?
My 90 has stock type shocks as far as I can tell, I have an el- cheapo 10 disc cd changer mounted in the console, basically screwed to the floor, and it does not skip.
