351 power numbers
Old May 27, 2010 | 11:55 AM
andyj ford driver's Avatar
andyj ford driver
351 power numbers
how much horse power should a stock 351 put out and what kind fo gas mileage should it get
Old May 27, 2010 | 12:06 PM
Newenglandfordjunkie's Avatar
Varies by year but most 87 to 96 models are rated at 210 hp with 315 to 325 lb-ft torque. Gas mileage is going to depend on gearing, 2wd or 4wd and model. I get 9-11 city and 15-16 highway with my 1993 F-150 extended cab 4x4.
Old May 28, 2010 | 08:31 AM
andyj ford driver
m truck is a 1995 f150 etended cab 4x4
Old May 28, 2010 | 08:37 AM
Conanski's Avatar
Conanski
With 3.55 gears and something close to stock sized tires the 5.8 will do 11-13mpg city and 14-16mpg hwy depending upon the transmission and the speeds involved.
Old May 28, 2010 | 09:14 AM
rla2005's Avatar
rla2005
I get 7-9 MPG city and 9-12 MPG highway with my '92 F350 4X4 w/5.8L & E4OD. Tires are stock height and 3.55 gears.
Old May 28, 2010 | 11:43 AM
Conanski's Avatar
Conanski
Leadfoot. On a serious note.. that is a heavy truck but it's still well below average, are you sure you don't have the fuel transfer problem?
Old May 28, 2010 | 12:40 PM
rla2005's Avatar
rla2005
I am 100% sure there is no fuel transfer issue. This truck is a tank. Full tune up, free flow exhaust, tires are properly inflated, no extra weight in the bed. No other accessories are installed to kill the little aero I do have. One of these days I need to put it on a scale to see how heavy it really is.
I have done numerous gas mileage checks running different speeds to see what the effects are. So far running 60 MPH in 4th yields the best of 12 MPG. That was measured over a 250 mile trip. Next time I'll try 3rd to see what happens. You should have seen it before I fixed all the sins from the previous owners and stock exhaust.
Old May 28, 2010 | 02:18 PM
Conanski's Avatar
Conanski
What rpm does it turn at 60? It should be well below 2000rpm so if it's not then you don't have 3.55 gears.. and that could explain a lot.
Old May 28, 2010 | 02:50 PM
rla2005's Avatar
rla2005
Right around 1600 RPM. I verified the speedometer was reading correct by timing it with the mile markers on the freeway. I've checked and checked again. The speed/odometer are dead nuts accurate.
Old May 28, 2010 | 04:45 PM
Conanski's Avatar
Conanski
Yeah that sounds about right for those gears and 235/75-16(30") tires. So there has to be something else wrong... because that is worse than what a lot of guys are getting with the 460.. which ain't right at all! I couldn't get less than 13mpg with the 5.8 in my (5000lb)truck.. and that's with me driving it like I stole it.
Old May 28, 2010 | 05:29 PM
rla2005's Avatar
rla2005
I agree the MPGs are low, but it is an improvement from when I started. I have replaced yards of vacuum hoses, checked timing (bumped it to 12), replaced items causing error codes (EGR,EVP,EVR) new O2 sensor, new exhaust, etc. The truck runs great, no error codes. Overall I am satisfied with the performance for a truck with 152k miles. No smoke, a small oil leak but otherwise very reliable. I need to start bumping the timing up to see what happens. Come to think of it the idle vacuum is on the low side, so maybe the balancer has slipped a little? Which leads me to doing a compression test...
colton04mclean
17
Oct 29, 2012 06:24 PM
sedly
Dec 27, 2008 10:07 AM
Magic
Apr 9, 2004 11:08 PM
bb78bronco
Jul 21, 2001 11:04 PM
knuckles
Jul 9, 2001 07:56 AM
