1978 - 1996 Big Bronco
1993 Bronco tailgate issue's help please
Old May 26, 2010 | 09:40 PM
Mrkline006's Avatar
Mrkline006
I have a 1993 Bronco. My tailgate is COMPLETLY rusted close, will not open no matter what i try. Any way i can open it without cutting it in half?
i did get a replacment tailgate but does NOT come with all the interior guts, where can i find a kit for it? or will a F 150 around the same year guts from there tailgate fit? any help would be grateful Thanks.
Old May 26, 2010 | 10:24 PM
g_k50's Avatar
g_k50
Smartass in me sez, cut it in thirds.
Take guts out of old tail gate.
Should be able to slice the bottom where it's rusted. Are you able to lower the window?
Can you take the interior panel off?
Old May 26, 2010 | 10:53 PM
psd tuner's Avatar
psd tuner
lmc truck is the place to get the tailgate parts...if you really wanted to spend the money they have new guts. mine got rearended and it wouldnt open, got a die grinder and cut the the top quarter of the skin off and i could reach all the stuff inside. it was a all day project cutting the old one and getting all the stuff out and putting the new one in. but you will have to work both inside and out getting the guts out...its a pita. also that little mechanism on the latch and be bent or the rod could be out of the hole, this happend to me on my f250.
Old May 26, 2010 | 11:06 PM
Encho's Avatar
Encho
The Southernmost Mod
Can you get the window down? If you can, then probably one of the rods that connect the latch to the locks broke, you will need to find someone that can weld it together (or you can replace it, most probably with a junkyard part).
To open the door take out the mat covering the interior of the tailgate, then remove the interior panel to access the internals, then you could try grabbing and pulling the rod (or broken pieces) with some locking pliers.
Old May 26, 2010 | 11:18 PM
Mrkline006's Avatar
Mrkline006
Yea the window goes up and down.. little slow, but works. I know i have some kind of rod in the back (i already took panel off) that it stickign out from the tailgate.. i figured its better to get a differant set of guts than try using my old ones. Wondering how much guts cost, or can i take one from a F 150 or sumthing???
Old May 26, 2010 | 11:23 PM
psd tuner's Avatar
psd tuner
f-150 are different i believe you can go to the junk yard or here: LMC Truck Parts - Page 35. if its goin down slow one arm maybe going down a little further than the other one causeing it to go down uneven even a little bit could cause it to go slowly.
Old May 26, 2010 | 11:31 PM
Encho's Avatar
Encho
Wow... mine is working well right now... but i would LOVE so much making a new tailgate out of all that parts in the LMC catalog and a new shell...
Old May 27, 2010 | 04:21 PM
Mrkline006's Avatar
Mrkline006
Anyone know a CHEAP place to get tailgate guts?? I live in MI, and its hard to find Bronco's let alone one's that are being part'd out.. So what i can gather F 150 guts wont work then correct?
Old May 27, 2010 | 04:40 PM
torque head's Avatar
torque head
look on craigs list. there's a bunch around the Detroit area. I would cut the the outside skin off and everything will come with it
Old May 27, 2010 | 09:17 PM
g_k50's Avatar
g_k50
A F-150 doesn't have a window.
Old May 28, 2010 | 12:43 AM
greystreak92's Avatar
greystreak92
Its not thick enough to house the guts (which includes a rather sizable piece of window glass if you recall) even if you could get them and the latch locations are different as well.
1974 f100
Apr 7, 2015 09:20 PM
fordka
WTB - Parts & other
Jun 6, 2014 08:37 AM
conchstew
Aug 21, 2012 01:25 PM
Dlooman
Mar 23, 2012 08:36 AM
neon4x
Jan 20, 2008 09:28 PM
