EBPV delete question
Old May 26, 2010 | 02:46 PM
DragnBotm's Avatar
DragnBotm
Deleting the EBPV how does this effect a truck in cold weather. I take trips to New York regularly and need to know what to expect in the winter.
Thanks
Rich
Old May 26, 2010 | 03:13 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
If you live in colder states, I don't think I would do the delete. If your glow plugs are working to start the truck, you could maybe get by without the EBPV.
EDIT: When temps are cold, the EBPV will close and the pcm will raise the idle to help the engine warm up faster.
Old May 26, 2010 | 04:49 PM
beanhead6D5's Avatar
beanhead6D5
I live in MO and didn't have any trouble in the winter.My truck will still fast idle without the EBPV pluged in.
Here's what I did when I deleted mine.
Ford Truck Enthusiasts Forums - beanhead6D5's Album: EBPV delete
Old May 26, 2010 | 05:50 PM
amthatiam's Avatar
amthatiam
I deleted mine last summer, went through this past winter with no problems what so ever, it did get pretty cold here for a while, temps as low as single digit, truck started no worries, no smoke and the high idle still works as it is controlled by the PCM. Their is a sensor on the pedestal, I pulled the sensor out of the old and plugged it in and left it in the valley. Their are a couple of companies that sell a "fooler", I chose not to go that rout as it will only throw a soft code anyway. Hope this helps.
Dan
Forgot to mention, I used Dieselsites EBPV delete pedestal.
brushfit
15
Jan 9, 2015 04:03 AM
86351wHOsupercab
13
Feb 14, 2014 03:22 PM
Mowing Man
Jul 30, 2013 06:29 PM
LSO1123
Apr 9, 2013 02:57 PM
