6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Oil Change Issue Update
Old May 26, 2010 | 12:28 PM
rjlabonte's Avatar
rjlabonte
Last month I posted a question (click below) about my 6.4 getting diesel fuel into the oil.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
After suggestions from this group I took it into the local Ford dealer. Thought I'd give you guys an update.<o></o>
<o></o>
Dealer worked with Ford folks and performed a number of checks and test. They found one of the exhaust pressure sensors slightly out of speck so replaced it. This didn't have anything to do with the diesel in the oil.<o></o>
<o></o>
After all the test they concluded that with the load (17,000 lbs RV, 75% of miles) that I tow I should get about one quart of fuel in the oil per 3000 miles of pulling. According to them everything is OK?<o></o>
<o></o>
Will be on the road again next month so will see how much oil/fuel I drain at the next 5000 mile oil change. I give you another update then.<o></o>
https://www.ford-trucks.com/forums/9...e-problem.html
Old May 26, 2010 | 12:51 PM
senix's Avatar
senix
I would short stick it everyday if I were you.
I assume they check the injectors to see if they were leaking?
Old May 26, 2010 | 01:01 PM
rjlabonte's Avatar
rjlabonte
By short stick it I assume you mean check oil level on the dip stick??? I now will check every time I hook up and pull out.
I can only assume they checked the injectors with the testing they did??
Maybe I should call dealer back and ask?
Old May 26, 2010 | 01:06 PM
senix's Avatar
senix
Yes the oil level on the dipstick. I would monitor the level closely.
Personally I would do my best to ensure they checked those injectors. They may or may not of.
I would assume there would be something written on your ticket when you picked the truck up.
Old May 26, 2010 | 06:58 PM
adamtheman16's Avatar
adamtheman16
International came out with a recall concerning an issue with the injector o-rings on these engines leaking fuel into the oil. The upper o-ring will cause this fuel in oil problem. International was able track down the specific injector serial numbers and which engine serial numbers had these defective injector o-rings. It even listed which cylinders they were. We then just replaced the injectors required by International.
I don't know if Ford has done the same thing in some form, but I don't see why any Ford engines would not have had this defective o-ring problem as well.
What needs to be done is the valve covers removed, then fuel system pressurized, and the upper injector o-rings inspected for fuel leakage into the crankcase.
Another problem that can happen is that if the engine was at some point taken apart (or not put together correctly at the factory), the metal injection lines under the valve cover going to each injector can leak if reused. The metal lines are NOT reusable as they are a one time swage when tightened down. If they are used again, they have the possibility to leak. This will also cause fuel in the oil.
Fuel should not be getting in the oil, period. It isn't normal on any engine.
Old May 26, 2010 | 07:07 PM
senix's Avatar
senix
Ford did the recall, here it is:
Fuel injector replacement, Field Service Action 07T07:
Certain trucks built at the Kentucky Truck Plant between 4-3-07 and 5-21-07 have three injectors that may have had their polarity reversed. Applicable trucks will have injectors replaced on cylinders 1, 5 and 7.
Old May 26, 2010 | 08:40 PM
adamtheman16
This recall that International did that I am talking about wasn't a polarity issue. It was an o-ring issue causing fuel in the oil.
Old May 26, 2010 | 08:42 PM
senix's Avatar
senix
that was the only one I that I can recall for ford.
Old May 26, 2010 | 08:52 PM
rjlabonte's Avatar
rjlabonte
Do you know when this recall occured? I have a 2008 F450 w/ the 6.4 diesel built in Jan. of 2008.
Old May 27, 2010 | 02:45 AM
adamtheman16
I'm not sure, but it may have only been International specific. I'll log into the International website tomorrow and see what the date was on it.
Even still, you shouldn't be getting fuel in the oil. It's not "normal"...
Old May 27, 2010 | 05:18 AM
senix's Avatar
senix
you can also go here and put in your vin and it will tell you:
Recall Information - Ford
Old May 27, 2010 | 11:48 AM
ChargersFanInCO's Avatar
ChargersFanInCO
Most people think the fuel in the oil (like qts of fuel) is from the regens...that makes me laugh.
Old May 27, 2010 | 05:27 PM
JD69X's Avatar
JD69X
Adam is correct. There was a recall of injectors for leaky O-rings. I know, my truck had the work done.
I have Job 3, 2008 F350 that had five injectors replaced. The notice covered trucks within a specific VIN range. As I recall, it was primarly Job 3 2008 built trucks but may had involved some Job 2 2008 trucks. My truck was built in Aug. of 2008. (Must of been one of the last ones off the line before the 2009's started being built).
Anyway, it's a cab-off process (not as big a deal as you'd think) and they did it in a day or so.
If you're in doubt, call a dealer and have them run your VIN. If it hasn't been done and should be, they can tell you (hopefully).
Old May 27, 2010 | 06:46 PM
Tom's Avatar
Tom
Originally Posted by cheezit
some oil growth is normal on the 6.4. the higher psi common rail will blow small amounts of fuel past the rings this happens most durring regen. Be very watchfull of the oil level in this truck. Very bad things happen to this engine when it gets way overfull. regular and timely oil changes is the only way to go.
Old May 27, 2010 | 06:50 PM
senix's Avatar
senix
Originally Posted by Crazy001
Enough said.
