6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Oil Change Problem???
Old Apr 12, 2010 | 12:30 PM
rjlabonte's Avatar
rjlabonte
Recently changed the oil and filter in my 2008 F450 w/ 6.4 diesel. Truck has about 32,000 miles on it. Noticed that I drained out more than 16 quarts of oil, approximately 18 quarts. Oil change interval was about 7000 miles and six months. Did the same last Oct., about 17 quarts, but didn't give it much thought at that time.
I have replaced the drain plug with the Fumoto drain plug so I am able to drain oil into milk jugs and know how much drains out. This is how I noticed I'm draining out more than I put in (16 quarts). <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
I'm guessing that fuel is seeping into the oil and diluting it. Please tell me this is not so!!! How big a problem do I have? Need you pros to jump in and clue me in.<o></o>
<o></o>
This is my first diesel but this does not sound normal. What say you??<o></o>
Old Apr 12, 2010 | 01:39 PM
senix's Avatar
senix
Fuel getting into the oil is usually caused by leaking injectors or the now famous regen issue to clean the DPF filter.
You can adjust your oil change interval to 5K, matter of fact I highly suggest that if you have a F450. You got the 450 to tow with right? So I would follow the severe maint. schedule.
So driving in the city, lower rpms will increase the fuel in the oil situation. Driving on the hwy, gettiing the regen over with it will help...or you may have an injector leaking.
Old Apr 12, 2010 | 05:52 PM
Subsailor1127's Avatar
Subsailor1127
I also have the 08' F-450 and was planning on the 5K oil changes. I have only put on about 500 since I bought it and they changed the oil at the dealer before I bought it. Got a little time to wait. Man.....I love this truck.
Old Apr 13, 2010 | 04:23 AM
ssharber's Avatar
ssharber
Also, some of us have found that having the oil analyzed at a reputable lab will tell you the condition of your oil, how much fuel may be in it, and as some of us have found, small levels of coolant in it. They do a fantastic job of letting you know how well your engine is performing and where to look if levels of something in your oil is too high. I, and others here, use BlackStone Labs, but I'm sure there are others. They will mail you a free container to fill at your next oil change. Just return mail them the oil, and for around $22.00 they will analyze it and report to you it's condition and any areas that may need looking into.
Old Apr 13, 2010 | 04:40 AM
scootyg69's Avatar
scootyg69
Putting 16 quarts of oil in and draining out 18 quarts in 7500 miles is a quite a bit of dilution. I would definitely run it @1000 miles and send in an analysis. If it's that much at 7500 then it will show at 1000. We test our oil every 4 hours here on our patrol boat for FOD(fuel oil dilution). We've never gotten more than .01-.06%. 5% is dangerous for crankcase explosions. Good luck and I'm jealous over the F450.......
Old Apr 13, 2010 | 06:04 AM
ruschejj's Avatar
ruschejj
Oil dilution is a problem with the 6.4 but it's cause is known so like with older motors it does not necessarily tell you that something serious is wrong. It is a grey line, the engine almost does it as a matter of it's normal operation.
It could be as senix states, injector issue but most likely it is just a fact of life with the 6.4.
Unburnt fuel is injected via the exhaust stroke down the exhaust pipe into the DPF during the cleanout cycle. The fuel burns inside the DPF to turn the collected soot into ash. During this process it is believed by several posters here that the raw fuel gradually works it's way into the crank case oil.
When I first got my truck back in 07 I went 10K between oil changes. The dealer service dept. told me that I needed to go to the 5K interval and have done so ever since. When the 6.4 first came out it was supposed to be a 10K interval, one of the "great" things about the new motor.
And by the way, those of you that don't drive your trucks daily, be sure you run the motor at least once/week up to operating temp. The injectors have been known to seize caused by sitting for extended periods of time.
Old Apr 13, 2010 | 08:57 AM
rjlabonte's Avatar
rjlabonte
Senix: Yes I got the 450 to tow my 17,000 lb 5th wheel.
To all of you that have responded, thanks for sharing your experiences and suggestions.
Am now in TX and headed home to WI, some 1200 miles. Will follow up, as suggested with an oil sample analysis and will talk to my local Ford dealer as soon as I get home.
Will let you guys know what I find out towards end of this month.
Again, thanks for your input, I appreciate it.
Old Apr 13, 2010 | 09:12 AM
senix's Avatar
senix
So with the F450 and towing use the severe maint schedule and do the changes at 5K and then filters at 10K is the recommendation.
Old Apr 13, 2010 | 03:10 PM
pyro2nite's Avatar
pyro2nite
The frustrating thing about this is, no one, Ford, Dealer, or inquires to different sites, tell you the acceptable amount of fuel in the oil. I have analyzed my oil; the readings are as high as 4.5%. I change mine at 5000-6000 miles wither I tow or not, because of the fuel dilution.
Old Apr 13, 2010 | 03:17 PM
jschira's Avatar
jschira
Originally Posted by rjlabonte
Am now in TX and headed home to WI . . .
NO! Y'all stay a little longer. Spend some more money. Won't be hot around here for a few more weeks.
Old Apr 14, 2010 | 02:14 AM
Thistle3595's Avatar
Thistle3595
Are you, or anyone else that is using the Fumoto drain plug, concerned about something knocking off the drain plug since it appears to stick down below the oil pan?
Old Apr 14, 2010 | 11:02 AM
sdetweil's Avatar
sdetweil
I bought one, haven't installed it yet for the same reason.
Sam
Old Apr 14, 2010 | 11:22 AM
pyro2nite's Avatar
pyro2nite
I got one and it is well worth the $20.00. After installation it really does not hang down. If you look around under the truck alot of things will get hit before the plug.
Old Apr 14, 2010 | 01:07 PM
origcharger's Avatar
origcharger
Do any of those other things keep the oil in the engine?
Old Apr 14, 2010 | 02:51 PM
pyro2nite's Avatar
pyro2nite
No...............My point was, if you are worried about knocking off the drain plug, it will take allot for something to hit it. Maybe all four tires suspended because the frame is high centered.
