**UPDATE** 30,000 miles on Royal Purple Synthetic ATF....No Issues
Old 07-19-2010, 08:49 PM
DSMMH's Avatar
DSMMH
DSMMH is offline
Originally Posted by amgpro2
Thanks for the clarification on SP being synthetic 69cj. I have used RP motor oil and love there stuff.
DSMMH, thanks for the info. I will be switching switching to RP ATF at the next filter/fluid change and see if it makes a difference temp wise.
Here are some case studies using RP: Royal Purple Advantage Why Use Synthetic Oil
Dow Chemical
* 30 oil misted ANSI hot water pumps
* 18 bearing failures per year
* changed major brand 68 to RP Synmist 68
* one bearing failure over next 3 1/2 years (vs. 68 historically over same period)
Premarc Corp.
* two 18,000 lbs fork trucks with Allison TRT2001 transmissions
* 1 to 2 transmission failures per year each @ $6,000 per incident
* changed oil to RP CMT 30
* temperatures dropped from 230°F to 180°F
* no failures in 6 years
* 6 year savings valued at over $50,000
King Fisher Marine
* 8-9 engine replacements per year historically with major brand marine engine oil - only 7 engine replacements in the last three years with Royal Purple Motor Oil
* 6 month life on turbochargers @ $1,000 each
* no turbocharger replacements in over two years with Royal Purple
* annual clutch replacements @ $10,000 to $30,000 each depending on damage
* no clutch replacements in 2 years with RP on 3 boats where this was a problem
* oil drain intervals extended 6 fold (from 350 hrs to 2,100 hrs) with Royal Purple
Clear Lake Cogeneration
* 450 HP vertical 3600 RPM motors driving 14 stage condensate pumps
* bearing life 4 to 7 months – failure severely damaged motor and pump ($14,000 per occurrence)
* changing oil to RP reduced temps. from 400°F to 160°F and increased bearing life to over 2 years
Royal Purple got it's start by developing an air compressor oil that increased reliability thus reducing down time. Seems this was a big problem in the air compressor industry. They were so successful with there compressor oil that contains their properity additive synerlec that they expanded there product line to just about every type of mechanical system lubricant.
DSMMH
DSMMH
03-07-2020 07:58 PM
DSMMH
12-07-2012 01:06 PM
DSMMH
02-16-2012 03:28 PM
DSMMH
03-08-2010 11:01 AM
DSMMH
01-19-2010 11:05 PM
Quick Reply: **UPDATE** 30,000 miles on Royal Purple Synthetic ATF....No Issues
