What tool do you use to remove the freeze plug on the side of the block of a V10? I noticed it does not have a head on it, rather uses a square head internally?
I'm not exactly sure what you're referring to, but I'm assuming that it's similar to the plug on the differentials. In which case you use the 3/8" or 1/2" ratchet or breaker bar with no socket. The ratchet should fit into the square hole just like you would attach a socket.
Originally posted by Waxy I'm not exactly sure what you're referring to, but I'm assuming that it's similar to the plug on the differentials. In which case you use the 3/8" or 1/2" ratchet or breaker bar with no socket. The ratchet should fit into the square hole just like you would attach a socket.
Clear as mud?
Waxy
Yeah....after reading the question again, kinda felt like a dork...didn't really make much sense.. But I think you got the right answer...I'll give it a try tonight
