I have a '99 F250 that has about 84,000 miles on it. I recently took it up in the snow and was shifting in and out of four wheel drive with no problem. I took it back into the city and I started hearing a clunking sound (yes I unlocked the hubs). This sound occurred at completly random times. It sounded to be in the front linkage or driveshaft. I checked all the bolts to make sure they were all tight and checked for any slippage and the clunking still was there. It then dawned on me that I should try the 4X4. I tried shifting (manual) at about 25 MPH into four wheel drive and the gears ground. I can shift into 4X4 when the truck is not moving. To me it sounds like the synchronizer has gone bad. I could be completely wrong though. Has anyone run into this problem? I could really use some help, I have never taken a transfer case apart. Thanks, John
Is this a manual shift transfer case?
I couldn't tell from your post.
if you were shifting in and out fine in the snow ,then here are some things to chk.
front drive shaft u-joints
front axle u-joints
make sure your hubs are both unlocked or lockedget under the truck and actually turn the shaft by hand to chk if there free .
sometimes water and dirt get in there and don't alow them to unlock
if this truck is an auto trans with a manual transfer case . put your auto in neutral and place the tranfercase in neutral any grinding?
put the transfer case in 4 hi did it grind?
same thing only try 4lo any grinding?
If so you may have a chain problem within the transfer case.
These transfercase are pretty tough but can be abused if not regularly maintained.
Notice I didn't mention if this an esof transfercase because I hate those!
First off, thanks for the reply. The Transfer case is a manual shift and the transmissioin is an automatic. I put the Tranny in neutral and the transfer case into 4hi and there was no grinding. I then spun the front drive shaft by hand and everything seemed to be ok. I am not real sure what to try next except to take apart the transfer case. Any pointers from anyone who has done it? Will I need a transmission jack or can two guys hold it? Any other suggestions?
Well, I just got back from a quick ride and, 4X4X4X4, you are right. You saved me a big mess. I really appreciate it. It sure is easy to make a big deal out of a little problem. But that still doesn't explain the clunking sound. Any other blatant things I seem to be missing
4x4x4 ,glad you step in while I was away from the puter. sure would not want that on my record
huh ! he he he !
yes you will get grind if the hubs are not locked and you shift to 4wh hi ,but if it grinds when the hubs are locked shifting into 4wh hi .
then we have a problem.
Did we find out if the clunking is only while in 4wh
or in 2wh also?
The clunking is while in 2hi. I have not heard the clunking in 4hi, but that is probably because I haven't been in 4X4 much lately. The clunking does not seem to be associated with anything with the drive line, steering or suspension. I am completely lost. It sounds like a bolt is loose somewhere and something is shifting back and forth. Pretty tough to find. Any ideas?
okay !
4x4x4x4 gave you some areas to chk !
here are a few more
trackbar brackets
swaybar brackets
pivot points (ball joints)
springs
spring u-bolts
steering stabilizer bracket and mounting bolts
