NEED HELP
Old May 25, 2010 | 10:19 PM
oreocreaming's Avatar
oreocreaming
drive the truck, as soon as it gets hot, shut the engine off. if the fan spins then the fan clutch is junk! it should lock up when your radiator gets hot.
Old May 25, 2010 | 10:28 PM
75Three90's Avatar
75Three90
thanks oreo
Old May 25, 2010 | 10:35 PM
oreocreaming
np. if the clutch fan is good (im guessing not) then pull your alternator, vacuum pump with the brackets off, then pull your thermostat housing and check that thing. gasket is only $4 for it. make sure its not fauled. easy way to check it (make sure its opening) is to boil some water, stick the thermostat in it. if it opens, your good to go. bolt everything back up. if your worried its your head gasket, thats a easy check. just take the radiator cap off, fill it to the top. fire the truck up. if it starts blowing globbs of air bubbles out then its your head gasket. its releasing compression into your cooling system. if all that is fine, i would run a radiator cleaner (or dish washer detergent) though it for a while, then run a flush. your radiator rows might have trash in them. i had mine hot tanked. 90% blocked with trash.
Old May 25, 2010 | 10:57 PM
75Three90's Avatar
75Three90
ok sounds good any way to help slow it down if it is a head gasket or to stop it?
Old May 25, 2010 | 11:12 PM
oreocreaming
ya, keep that thermostat off, bolt the housing back on. theres a green bottle of head gasket seal at your local auto parts store. its like lime green, looks like a quart of oil. its about $30 but it will do the trick.
Old May 25, 2010 | 11:18 PM
75Three90's Avatar
75Three90
oh ok kool i also heard liquid glass will seal it
75Three90's Avatar
75Three90
also could you get a picture of it for me? you guys are great lol
Old May 25, 2010 | 11:24 PM
joe f350's Avatar
joe f350
hope u get it fix for ur date the truck bed are good for that
Old May 25, 2010 | 11:28 PM
75Three90's Avatar
75Three90
yeah i know i have another truck but shes a gas hog, shes nicer than my diesel bigger than my diesel but i like my diesel better cause its diesel lol
Old May 25, 2010 | 11:48 PM
joe f350's Avatar
joe f350
the hard part is finding the problem hope it ant the hg
Old May 26, 2010 | 12:06 AM
oreocreaming
liquid glass is alright, for a little while. one sec, i'll post a pic of the stuff. i just happen to have a spare bottle in my shop.
Old May 26, 2010 | 12:09 AM
joe f350's Avatar
joe f350
u got a shop lucky
Old May 26, 2010 | 12:14 AM
  #28
oreocreaming
Old May 26, 2010 | 12:21 AM
  #29
oreocreaming
2400 sq ft. its nice, blows i cant fit in the back half where the tools and lift are. my dad and i are goin halfs on getting a lift to put outside so we can work on our trucks on a lift. be good to pressure wash under the cars too...
Old May 26, 2010 | 12:22 AM
  #30
75Three90's Avatar
75Three90
thanks thatll help
B&B TOWING
Mar 16, 2012 12:50 PM
LARIAT 85
Mar 18, 2009 04:58 PM
leadhorse
Nov 21, 2008 08:35 PM
wolfpakc
Sep 5, 2006 08:12 AM
AlexSyntec
Feb 4, 2004 09:27 PM
