Carburetor "Hot Air" Choke Hookup to 1985 F150
I am going to hook up an Autolite 4100 4V carburetor to my 1985 Ford F150. This carburetor uses a "hot air" choke instead of an electric choke, which I understand is actually better. However, I am not sure how to install the "hot air" and the "fresh air" tubes.
There is a "hot air" tube that goes from the choke down to the manifold someplace and then another "fresh air" tube that supposed to hook up under the carb plate somehow, but then I do not know where the other end goes.
The next thing is I am now running long tube headers, and they do not have the "stove" needed to hook the "hot air" tube to. Is there another way to make this "hot air" choke work with headers?
Any help would be appreciated!
Personally, I would put an electric choke thermostat on it, run a wire from the "S" terminal on the alternator, tweak the adjustment as needed and call it done. The electric is a bit less finicky.
'77 F100 Custom
12-06-2016 09:01 AM
Dago Red
05-06-2016 02:50 PM
dwinne
04-21-2016 06:21 AM
Sportsterengr
02-28-2016 03:12 PM
6978sghfbjklgdfsjhkl
02-22-2012 09:21 PM
