Suspension
Old May 25, 2010 | 04:59 PM
TheTowingCowboy's Avatar
TheTowingCowboy
Suspension
Howdy yall.
I am doing a PSD conversion to my truck, and restoring it all at the same time. Anyways I was wondering about add a leafs for the front. Do they make add a leafs for 75 F250 High Boys? If so where could I order me a set? I am doing all the suspension and stuff, so I can use it as a DD, and do some sled pulling on the side. Also I want to put Rancho 5000 shocks all around, I already found the front ones, but there are multiple options for the rear going from 22 to 24 and I think some are even more. Mine measures from mount to mount 20, so would it matter which ones I get? ANd if it would help my truck has the factory 4 inch block in the back. I want to have good stiff suspension. No I am not going to be doing any off roading. Thanks guys much appreciated.
Old May 25, 2010 | 06:21 PM
75F350's Avatar
75F350
You will purchase any add-a-leaf to any spring pack based upon the length of the spring, the width of the spring, and the arch of said spring, not necessarily a specific application.
One huge dimension to consider is the center bolt location. This will have to be as close as possible to the factory dimension in order to prevent one end of the AAL from sticking out from either end of the pack.
Your stock 75 spring pack will support the added weight of the PSD. You might consider simply installing the engine, and then making the required spring change after you drive and work the bugs out. many PSD and cummins conversions did not require suspension mods.
Much of this has to do with the condition of the original spring. If yours are shot, this might be the time to rebuild the entire pack and not just throw in the AAL.
If the spring pack is weak, the AAL will not last long as it will not support the weight for very long, and you will eventually have to rebuild the pack anyway.
Old May 25, 2010 | 06:28 PM
Fordworth's Avatar
Fordworth
75F350 is right. I've done lots of mixing and matching in the past on my truck to achieve different results. If you do want a simple application specific add a leaf, however, try Rough Country. I bought a pair from them several years ago and they lifted the nose about 1 1/2" and made it ride better.
Old May 25, 2010 | 10:03 PM
TheTowingCowboy
well I assume there still good cause they still smile at me a little and the truck has the regular amount of 4X4 slope to it.
76ClydeF100
Mar 7, 2015 05:42 PM
ford #7
Jun 21, 2012 11:55 PM
AntiHero55
Jul 22, 2010 09:50 PM
cletus_the_red
16
Feb 19, 2008 07:34 PM
nhswrld
23
Aug 27, 2006 07:59 AM
