Sponsored by: Auxito
help me fix my A/C!
Old May 25, 2010 | 03:33 PM
93 mix 'n match's Avatar
93 mix 'n match
help me fix my A/C!
so im finally getting around to getting my A/C working. its fully charged but the pump wont kick on. what controls the pump, where is it, and how do fix it easily and cheaply.
Old May 25, 2010 | 05:05 PM
steve(ill)'s Avatar
steve(ill)
12 volts to the clutch will make it kick in and pump. see if you have 12 volts on the wire, and the clutch is bad... if not, then the power comes from a fuse, thru the low pressure switch. compresor kicks off if you have under 20 psi (i think) in the suction side of the pump. you cn put 12 volts to the plug if you want to test the compressor and clutch.
Old May 25, 2010 | 05:43 PM
93 mix 'n match
wheres the fuse and low pressure switch? which wire is the 12v to the pump?
Old May 25, 2010 | 06:22 PM
preppypyro's Avatar
preppypyro
check the gap between your outer clutch plate, and where it contacts the clutch pulley (not sure if Im using the right terminology)
Should be .35-.75 if I remember right, I just did mine on my superduty this weekend.
Old May 25, 2010 | 08:39 PM
93 mix 'n match
guess what! i jumped the low pressure switch and my ac works perfect. now i also dont get warm air at a stop.
90' XLT
Jul 30, 2022 02:22 PM
cousinjc
Jun 24, 2010 11:38 PM
SoCalJess
Aug 8, 2008 01:42 PM
sleepysal
Dec 1, 2004 06:36 AM
soy4soy
Bronco II
Apr 5, 2003 04:57 PM
