Tow Vehicle Wiring Problem
Old May 24, 2010 | 05:42 PM
tgirl750's Avatar
tgirl750
I tow a 17' Bantam Flier with my 2001 V-8 Mercury Montaineer and the right turn signal and break lights have been intermittent for a couple months. I have ruled out a problem with the trailer and narrowed it down to the vehicle.
There is a sealed plastic junction box installed on the rear chassis that, when tapped or beat on, causes the lights to come on or go off whichever is the case.
The junction box is labelled (truck) with four wires coming in and (trailer) with two wires coming out that feed the left and right turn signals and brake lights for the trailer.
The RV dealer assured me that this was a factory installed part and I highly doubt that since I haven't been able to find a similar substitute.
I've been toying with the idea of splicing the two wires together (from the vehicle to the trailer) but I'm not sure if there's a diode within the box that's needed for proper operation.
I'd be perfectly happy to replace the entire 6-pin connector and the junction box if I could find one.
Hope this post isn't too vague but...with Memorial Day weekend coming up I'd certainly hate to have to leave the trailer at home!
Does this sound familiar to any of you?
Old May 24, 2010 | 09:54 PM
shorod's Avatar
shorod
That box does not sound factory. If they spliced in to the factory wiring to install that, the problem with the lights is probably due to corrosion getting in to the wiring and corroding the copper. There is a trailer wiring connector installed by the factory under the body near the driver's side rear tail light.
If the box was spliced in to the factory wiring and corrosion occurred, unfortunately you'll likely need to replace a foot or so of each of the spliced wires to get clean enough wire to solder to. Be sure to protect the splices with adhesive-lined shrink sleeving.
-Rod
70runner
Nov 4, 2012 01:27 PM
skoveng
Electrical Systems/Wiring
Feb 24, 2009 07:07 PM
jonstar
Dec 28, 2007 01:28 PM
jad4
Nov 7, 2005 09:27 PM
partsman1
Apr 29, 2004 08:35 PM
