E4OD shifting and squeak questions
Old May 22, 2010 | 01:54 PM
davelength's Avatar
davelength
My van has developed a few strange transmission issues that I am hoping someone can shed some light on.
First off, what is the transmission doing when you feel what seems like a small shift within a given gear? In other words, if the vehicle has just shifted into 3rd, and I put my foot into the gas (but not enough to make it down shift), about half way through the power band, it feels like it makes a small shift and it pulls a bit harder than it was before. Is this the torque converter locking up? Something in the valve body changing position?
Part of why I am asking about this is because the van has been making a loud high-pitched squeaking noise that seems like it is coming from the transmission. The noise is similar to a belt squeaking, but the pattern is completely different. It does not make the noise when revving the engine in neutral or park. The noise also stops if I shift into neutral while rolling down the road.
The noise only occurs when I am in gear and accelerating or holding the gas steady. It is intermittent and goes away after about 20 minutes of driving. It seems to happen more when I am driving at a low rpm in a high gear, or it often starts when the transmission does one of these "half-shifts." Once the squeak noise starts, it will continue (getting louder and faster) until the transmission shifts again or I let off the gas.
Any thoughts on what this sound could be? I tried to use a video camera to capture this noise, but the camera could not pick up the sound.
Some info that could be relevant:
1994 E350 with 5.8
Transmission was rebuilt about 10k miles ago
I had the transmission out about 3k miles ago when I rebuilt the engine. I installed a TransGo shift kit, replaced the fluid (Dex/Merc) and filter at that time. The noise seems to have started when I put everything together 3k miles ago.
Thanks!
Dave
Old May 22, 2010 | 02:55 PM
lew52's Avatar
lew52
I don't know about the trans but i would have a good look at the U joints on the drive shaft ....Lew
Old May 23, 2010 | 12:54 PM
davelength's Avatar
davelength
Interesting, though I suspect not. I replaced all the u-joints with Spicer ones when I did all the other engine/transmission work. I'll check for play and hit them with some fresh grease.
Any other thoughts? I know a squeak noise is not common with a transmission like this, but this definitely seems drivetrain related. I should also note that this is 4wd, though most of the front components are not moving while I am in 2wd. Could a BW1356 make an odd noise like this?
Thanks!
Dave
expy37at
Oct 10, 2019 06:26 PM
Inline66
Apr 24, 2017 09:29 AM
rob_jones
Sep 11, 2015 10:15 AM
06f150CO
Modular V8 (4.6L, 5.4L)
Feb 21, 2011 06:10 PM
riggz
Dec 8, 2008 05:29 PM
