timing question
Old May 23, 2010 | 04:00 PM
frankyford's Avatar
frankyford
timing question
Okay, on my 95 F150 302 auto. My buddy Joe and I really went over this thing and we still can't figure it out. We think it might have jumped timing, but would'nt it run a whole lot worse than what it is. It idles fines and it will even run good for a while and then bog down or stumble under light acceleration, but when you put it to the floor it will go. We took the dizzy cap off and the rotor is pointing at the no.4 position on the cap. Reposition the wire to accommdate this and it would not start and could not get the the timingh light to come on. Does this sound right to anyone. Thanks
Old May 23, 2010 | 04:19 PM
lew52's Avatar
lew52
You need to turn the motor tell its on TDC on the compression stroke & see if the rotor is at #1...Lew
Old May 23, 2010 | 04:26 PM
frankyford's Avatar
frankyford
Yeah we did that and it the rotor was still a little off. When he hit with the timing light, he couldn't see the mark. When he got up under the truck, the mark was on the bottom of the damper. We played with the timing but it wouldn't come up. It's real hard to explain by trying to type all this, but I'll do my best.
Old May 23, 2010 | 04:34 PM
lew52's Avatar
lew52
Maybe your balencer has sliped , have a good look at the rubber , im sure your putting the timing light on the #1 wire with the spout out ...Lew
Old May 23, 2010 | 04:47 PM
frankyford's Avatar
frankyford
Yeah spout connector is out with the timing light on the #1 wire. A friend of his mentioned that earlier, so I think you just hit something. That would also make it run rich correct or stumble on light acceleration? What's the procedure for correcting it. Thanks
Old May 23, 2010 | 04:53 PM
lew52's Avatar
lew52
If the balencer sliped you just need to replace it ...
Old May 23, 2010 | 06:13 PM
frankyford's Avatar
frankyford
Now if I could figure out why it's running rich.
joe blow
Jul 24, 2011 08:31 AM
Mocha Joe
Mar 9, 2007 02:03 PM
85vanman
Jul 5, 2002 06:39 PM
