1.7 rockers
Old May 21, 2010 | 05:14 PM
ac700wildcat's Avatar
ac700wildcat
1.7 rockers
I was told on here that a set of 1.7 rockers would make more sense than a cam right now for my sd computer. So right now I'm trying to figure out what set of rockers to buy. What specs should I be looking for concerning self aligning or non self aligning. Summit lists stud, shaft, and pedestal mounted rockers. Which ones do I need? I'm guessing stud, beings thats what Summit lists the most of. What size stud? Am I going to need new push rods?
Any suggestions would be great. $200-300 is my budget for the rockers and of course staying closer to the $200 mark would be great. Sorry for all the questions, but I'm a motor newb.
Old May 21, 2010 | 05:20 PM
ac700wildcat
I suppose I should add that they will be going into a 91 302 motor and I will be swapping all the roller components out of my 94 motor into it.
Old May 21, 2010 | 05:29 PM
lew52's Avatar
lew52
If you have stock heads they will be pedestal mount , just bolt on ....Lew
Old May 21, 2010 | 05:32 PM
ac700wildcat
Yes, they are stock heads.
Old May 21, 2010 | 05:37 PM
lew52's Avatar
lew52
Then there pedestal mount , no adjustment , just TQ down
Old May 21, 2010 | 07:18 PM
ac700wildcat
Thanks. Going through summit I have a few options.
Scorpion 1.72 $237.95-274.95 race series-endurance series
Airflow Research 1.72 $269.95
Proform 1.7 $175.95
Crane 1.7 $209.95
Will I need shims? Also, will there be any valve cover clearance issues?
Thanks
Old May 21, 2010 | 07:32 PM
lew52's Avatar
lew52
I run the scorpion 1.72 , there nice , usally no shims are needed , with the stock cam the covers should be ok , i use taller valve covers so im not 100% on that...but if you take the baffels out of the covers they will work....Lew
Old May 21, 2010 | 10:12 PM
86F150302's Avatar
86F150302
Like Lew said you might have to take the baffles out of the stock VCs to get the 1.7s to fit.
Old May 22, 2010 | 01:05 AM
cjben's Avatar
cjben
you might look on ebay if you have time. I got a brand new set of crane's for less than half price of anywhere else I could find them new.
Old May 22, 2010 | 07:39 PM
ac700wildcat
One more question. Do I want the scorpion racing rockers or the endurance? What is the difference? Ok, I lied....that wuz two questions.
Old May 23, 2010 | 05:41 AM
lew52's Avatar
lew52
I didn't know they made two kinds of rockers ??
Old May 23, 2010 | 03:24 PM
ac700wildcat
Well summit lists two different part numbers, one for the racing and one for the endurance. Scorpion lists two numbers too, one for the racing and one for platinum series. The numbers listed for the racing series match, but the platinum and endurance numbers don't match. The number that Summit lists for the Endurance series doesn't even show up on the Scorpion website. Kinda an odd thing. Reading through Summits description for the Endurance series, they are made to fit under factory valve covers.
Old May 23, 2010 | 09:21 PM
George84's Avatar
George84
Would that be the same for the 96 351w too?
Old May 24, 2010 | 05:20 AM
lew52's Avatar
lew52
The 96 will be pedestall mount , i use stud mount because my heads have screw in studs....
F-250 restorer
45
Mar 30, 2010 10:09 PM
nextalcupfan
18
Jan 3, 2010 01:40 PM
BRay09
Dec 20, 2009 06:44 PM
rog_j
15
Oct 28, 2004 08:33 PM
TOUGHY17
Nov 6, 2001 10:27 PM
