Engine Died Today
Old May 21, 2010 | 10:38 AM
shmrock5's Avatar
shmrock5
Engine Died Today
My 2006 6.0L was warm, idling, died and won't start. Cranks fine so good batteries. Right over 100,000 miles. Was running fine. No choking or sputtering before it died. Any ideas??
Old May 21, 2010 | 11:40 AM
gearloose1's Avatar
gearloose1
Go to tech folder, and look up all the causes of no start.
Work down the list, from no fuel, no oil, to more complicated causes.
Old May 21, 2010 | 11:45 AM
cartmanea's Avatar
cartmanea
If it will restart after fully cooling off, it could be the STC fitting on the HPOP leaking. Very common problem on '05-'07 trucks.
Old May 21, 2010 | 05:42 PM
shmrock5's Avatar
shmrock5
still broke
just change the cam sensor , still wont start, no glow plug light, no start-up noise that i'm use to like a solenoid or fuel pump or something. I'm broke in my driveway do I tow to dealer? (don't want to)
Old May 21, 2010 | 05:44 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Start checking fuses
Old May 21, 2010 | 05:48 PM
69cj's Avatar
69cj
If all fuses are good start wiggling harnesses.
Old May 21, 2010 | 05:49 PM
bismic's Avatar
bismic
Did you look through the no-start checklist? These things are complicated and internet troubleshooting is very hard .........
Old May 21, 2010 | 06:15 PM
shmrock5's Avatar
shmrock5
new guy info
sorry new, where do u find tech reports or the start up checklist?
Old May 21, 2010 | 06:31 PM
bismic's Avatar
bismic
Tech Folder:
https://www.ford-trucks.com/forums/3...ch-folder.html
No-start checklist:
https://www.ford-trucks.com/forums/8...condition.html
Old May 21, 2010 | 06:41 PM
cheezit's Avatar
cheezit
things to try.
first check for codes.
check fuse f2-22
disconnect ebp attempt to start
disconnect icp attempt to start
Old May 21, 2010 | 07:02 PM
shmrock5's Avatar
shmrock5
possibillity
If I had low oil level or oil pressure would it stop my engine and stop me from starting? would it stop the glow plug light from comming on? just asking questions before I start checking fuses.
Old May 23, 2010 | 08:01 PM
4ord06's Avatar
4ord06
Short answer, yes.
