What kind (brand/model) aluminum intake should i get for my 351m/400? It is just stock 2bbl right now and i am going to get a 4bbl (not sure what brand yet). Also where is the best place to order one from? I also want to add headers but not sure what brand to get or what kind to get. My truck is a 77 f250 ranger 4x4.
For what it's worth....
My stock 302 in my '74 F100 originally came with a cast iron intake and a Motorcroaft 2 BBL.
I replaced the cast iron exhaust manifolds with Flo-Tech headers. (They have a solid 1/4" mounting flange to keep from developing exhaust leaks.)
I replaced the intake with an Edelbrock Performer 289 aluminum intake.
I also replaced the carb with a brand new Holley 600 cfm 4 bbl.
I will note this: I installed all this on August 1, 2009 the week before Old Blue went to the body shop for paint. Blue spent from August until NEw Years in the body shop and ran fine to move around inside and around the shop. I picked Blue up and within 35-40 miles of driving the new Holley carb began flooding the engine at will. It occured at idle or 50 MPH. No rhyme or reason. I had my mechanic look at it and he determined that the new $300 Holley was sucking fuel around the metering block. You could adjust the air/fuel mix all the way in or out and there was no change in the way it ran (or attempted to run). I contacted Holley and they advised the warranty was only 90 days.
I sent it back and said they found nothing wrong. I installed the carb again...same problem. I have argued with Holley and they refuse to replace or refund (they no longer allow the retailer to warranty items) my $300.
I have since picked up a used (7 year old Holley 600) and had it rebuilt. I installed it and the truck has been running perfect.
My point is don't get a Holley, their customer service sucks. Either get a used Holley (older style) and have it rebuilt or get a new Edelbrock carb.
I'm happy with my performance on the older carb and also have a really nice and shiny Holley 600 paperweight.
I will be upgrading the cam to a mild performance cam at a later time. I guess I am looking to get more hp out of it. Doesnt really matter to me if it is highend or torque. The truck has alot of torque as it is so i guess highend. Im not sure on the headers as far as clearence goes. Should i get shortys of full length? Is there any other header options i should look into? Also should i get a non egr intake or an egr intake? I have a egr vavle on it right now.
Hey i have a 78 F150 Ranger 4x4 with a 351m and its sweet it has a Holley 4bbl paired up with a EDELBROCK PERFORMER 400 Intake manifold and it also has HEADMAN HEADERS from LMC truck lol just thought i would give that knudge lol
i'd say run a holley carb. i had both and my edelbrock carbs sucked.. a holley just makes better power and runs crisper, the eddy's always have a dead spot. at least both of mine did and i could never tune it out, my holley worked great thou..
Are your headers shorty's or full length? What part # are they so i could look t them?
I also want to put in a mild performance cam, will that have anything to do with the intake and carb i get? Do they all need to be paired up or anything?
get an edelbrock performer intake, holley 650cfm carb, long tube headers and a mild cam from comp or crane.. also replace that timing chain, nows the time to do it.. thanks
i had the same problem but with 3 diffrent hollys and had diffrent people at the track try to tune then slaped on al edelbrock and never had a problem with it and i also have the flotec headers and edelbrock perfromer rpm intake and where to buy i use summit to find what i want and go to my local perfromance shop i would rather help out people that actouly race with me then some big fat rich guys smoking cigars that are worth more than my truck
