truck set up
You could also go with a roadranger like a 6610. They have already been mated to cummins so no after market adapter is needed. Only have to have the drive line mated to the rear end.
Several things you can do with the Cummins. Injection pump is a P-pump, there are after market bolt on parts to up the power. Injectors can be changed, turbo tweaked or swapped. The Cummins can make impressive power and torque and still remain a reliable power plant as long as you don't go overboad.
The reason for a Cummins is money vs end product. To get similar performance from the International engine, you would have to have a powerstroke which would mean computer and wiring harness to go with. If you had an inexpensive donor truck, it would only be labor intensive. 94-97 Cummins makes good power but doesn't need a computer or the sensors that go along with it. Plus the Cummins was put in many mid size trucks, using many different transmissions which gives you a lot of options.
fordf348
05-22-2015 06:54 AM
aliciamc
07-19-2013 05:33 AM
