Air Bags
Old Jun 17, 2010 | 02:46 AM
1L243's Avatar
1L243
Air Bags
I just purchased a new toy hauler bumper pull. It will be just under 10k when loaded. Tongue wieght is around 1100lbs and I am using a load leveler hitch. The truck is a 1999 F250 7.3 2WD with auto trans. When loaded the truck is slightly down in the rear from level. I have purchased some air lift load lifter 5000 air bags with a on board air compressor system. Some drilling is required with this kit. I have not installed them yet. Was looking for some feed back.
Thanks
Old Jun 17, 2010 | 02:40 PM
senix's Avatar
senix
I have firestone ride-rite's on mine. they work great. Airbags can be well worth it. Also for your case I think you could also consider just using a add a leaf.
Old Jun 18, 2010 | 07:52 AM
kermmydog's Avatar
kermmydog
I use the AirLift 5000# bags on my 86 F250 4x4. my trailer tongue is around 750#. I have run these bags for 5 years now. I just use the standard system. Were you air them. Less problems IMHO.
Craig
Old Jun 18, 2010 | 10:53 AM
1L243's Avatar
1L243
Is there any ride difference in the trucks ride when not towing and the air bags deflated? I checked out the add a leaf and I dont want to change the ride or raise the truck any when not towing.
Old Jun 18, 2010 | 12:34 PM
senix's Avatar
senix
no difference I leave about 20 lbs in mine when empty. You have to have a little in them so you don't pinch them. Ride is the same.
speakerfritz
Oct 21, 2013 10:42 AM
FX4DaDtoplay
All Things Towing
13
May 19, 2011 08:44 PM
awq134
2009 - 2014 F150
Oct 28, 2010 09:11 AM
60RatRod
13
Sep 19, 2010 09:18 PM
GarryDavis
Mar 19, 2010 04:21 AM
