truck set up
Old Jun 5, 2010 | 12:12 AM
hardwork's Avatar
hardwork
Post truck set up
Okay I plan to use a f-350 dually as the base rig. what modifications should I do to make the truck two a big toy huller cross country yet get good mileage and nice ride quality with out hurting it to bad?
Old Jun 5, 2010 | 06:55 AM
mistakenID's Avatar
mistakenID
First off, need more information on the truck, engine size-type, trans, gear ratio. Second the length, weight of the trailer. What does the front of the trailer look like? Big, flat area is like trying to drag a sail.
Old Jun 5, 2010 | 10:42 AM
senix's Avatar
senix
Yeah,
I think more info is required. If you don't have the truck yet, then it is best to start with the toy hauler. Make/Model/Spec's and then we can match the truck to go with it.
Old Jun 5, 2010 | 11:09 PM
hardwork's Avatar
hardwork
I just have the frame and body for the truck,but it an 2003 on jack-stands
Old Jun 6, 2010 | 05:44 AM
mistakenID's Avatar
mistakenID
In that case, I'd go with a 95-97 Cummins BT 5.9, 6 sp manual trans and Ford, duel rear end with the 3:54 gears because it's a straight bolt in. Tweak the cummins just a bit and it will give you good power, mileage and work well with a 6 speed and higher gear rato. The over drive in the 6 speed will help with mileage also.
You could also go with a roadranger like a 6610. They have already been mated to cummins so no after market adapter is needed. Only have to have the drive line mated to the rear end.
Old Jun 7, 2010 | 11:28 AM
hardwork's Avatar
hardwork
Thanks and this tweaking of the Cummins would be what
Old Jun 8, 2010 | 06:44 AM
mistakenID's Avatar
mistakenID
Several things you can do with the Cummins. Injection pump is a P-pump, there are after market bolt on parts to up the power. Injectors can be changed, turbo tweaked or swapped. The Cummins can make impressive power and torque and still remain a reliable power plant as long as you don't go overboad.
The reason for a Cummins is money vs end product. To get similar performance from the International engine, you would have to have a powerstroke which would mean computer and wiring harness to go with. If you had an inexpensive donor truck, it would only be labor intensive. 94-97 Cummins makes good power but doesn't need a computer or the sensors that go along with it. Plus the Cummins was put in many mid size trucks, using many different transmissions which gives you a lot of options.
mr78F150
Jun 18, 2015 12:50 AM
fordf348
May 22, 2015 06:54 AM
1972fordhighboy
15
Dec 19, 2014 12:46 AM
aliciamc
Jul 19, 2013 05:33 AM
jkidd_39
6.4L Power Stroke Diesel
18
Oct 12, 2010 11:31 PM
