Yessir.... it could mean it is cracked and usually not reading correct pressure, not to mention oil geting on the wires .... I got my last one for like 75 bucks on ebay....
Just to clarify the ebay part I bought was OEM ...the International one is 1 1/8 and the Ford one is like 5/8 ..I used a deep socket and Torqued it same as the oil plugs (40 lb-ft ?)
OK guys i was checking out the ICP that on my truck and it looks round on top wit a nut below, but does not look like you can get a deep well socket to go over it to remove. It looks this way in a few pics ive seen as well. The new 1s however look as if you can use a socket to install.
I guess i need to just wrench it out slowly?
