Lose of fuel pressure
I have a 01 f350 7.3 & when I start my truck it runs for about 30 seconds & shuts off. Then I have to turn & hold the key & hold the fuel pedal to the floor for about 15-25 seconds untill the motor starts. & it runs for about 6 seconds & shuts off. I repeat this about 15 times it seems.... Then finally it will start & idol great. But when I try to drive it looses pressure & shuts off & I have to turn & hold the key till it start again. This will happen a couple more times & then it sputters untill it can substain pressure. I've replace the fuel drain bulb,fuel filter, new frame pump,dropped & cleaned fuel tank & tank pump!! I need help! O yea fuel leaking on the top of motor & sitting in canal. Any advice please???!
on
Ditto. Guys, just for his information (and mine), will he need to remove the turbo and pedestal to replace that fuel line? I can't remember. I do know it is very easy to see when the fuel bowl, turbo, etc. are pulled out!!!! Ha.
^^^ No, that isn't really necessary but if you had it off anyway it would make it much easier. The only thing I moved was the passenger side CAC pipe and passenger side lifting eye. I was able to weasel my hand back in there to disconnect @ the head, and also to remove the clip to pull the line off for thorough inspection.
Redneckfordf2502002
16
01-08-2014 05:04 PM
