Extended crank time
Old May 19, 2010 | 10:19 PM
Bob Taulbee's Avatar
Bob Taulbee
Duct Tape Tech.
When the engine is hot or warm, the starter will have more resistance and will draw more amps to crank. You may have a starter trying to tell you something. Check the amp draw cold and when hot, see if there is a difference.
Old May 20, 2010 | 06:42 AM
bdrummonds's Avatar
bdrummonds
Originally Posted by bama29fan
yep going to shaefer heard. actually going this weekend also. have you been there? it's probably our favorite campground for relaxing so it helps that it's also the closest to home. we were debating on wind creek but since it's been a while since we've camped we were wanting to relax...we go to wind creek for the party
Nope, havent stayed on Westpoint yet. Might have to get over there one day. Ive got to finish the cleaning of my camper, and start with the loading here pretty soon. I hate preparing for that first trip of the year, we always forget something.
Old May 20, 2010 | 06:59 AM
just another truck's Avatar
just another truck
Brandon, packing already for RRE???
jk
Old May 22, 2010 | 11:49 AM
jt371's Avatar
jt371
______
My truck is starting the extended crank when hot as well. If I just get in and hit the key when it is hot it will crank longer. If I turn the key on and give it a couple seconds then turn to start it will fire right up.
Old May 24, 2010 | 08:10 AM
bama29fan's Avatar
bama29fan
Just an FYI...
i replaced the ICP because it had some oil breaking thru....havent had the longer start time yet. Hoping that is it and the IPR is ok for now.
Old May 24, 2010 | 09:35 AM
jt371's Avatar
jt371
______
Checked my ICP this weekend, has oil leaking through it as well. I'll look at changing mine as well.
Old May 24, 2010 | 10:11 AM
jbounds's Avatar
jbounds
This could be the cause of my extended cranking as well.....where is the ICP located on the 7.3's? I have an E '99
Old May 24, 2010 | 10:44 AM
bama29fan's Avatar
bama29fan
Front of Drivers side Head
Old May 24, 2010 | 12:39 PM
jbounds's Avatar
jbounds
K thanks....and I should be able to just take it out and clean it correct? or do I have to buy a new one?
Old May 24, 2010 | 12:49 PM
donnyglaze's Avatar
donnyglaze
Sorry to be ignorant, but what are the ICP and IPR? My truck's been cranking longer too. Is this a hard fix?
End Thread Jack
Old May 24, 2010 | 01:04 PM
bama29fan's Avatar
bama29fan
I still learning about my truck as well but from what i gather the ICP (Injection Control Pressure) is a sensor that detects the HPO (Higi Pressure Oil) and tells the IPR (Injection Pressure Regulator) how much pressure is needed in the Injectors. The injectors in our trucks work off of very high pressure oil.
The IPR (if leaking) can be rebuilt with some cheap parts
Replacement O-rings for Ford Diesel Engines
The ICP however needs to be replaced
Riffraff Diesel: Motorcraft ICP Sensor
....both are fairly easy to do yourself
Old May 24, 2010 | 01:23 PM
bama29fan's Avatar
bama29fan
heres some more info for ya...
IPR rebulid guide
New Page 0
Old May 25, 2010 | 01:07 PM
  #28
jtybt's Avatar
jtybt
I've been reading all I can but not all the acronyms have a definition/translation.
What is an IPR or ICP?
Thanks,
Charlie
Old May 25, 2010 | 01:10 PM
  #29
donnyglaze's Avatar
donnyglaze
I just learned that the other day.
Old May 25, 2010 | 03:08 PM
  #30
jtybt's Avatar
jtybt
Hey Donnie, Thanks!
Ain't this fun...like going back to school.
Gregad
Mar 24, 2015 10:12 AM
Gregad
Mar 22, 2015 07:31 PM
End of the Road
22
Aug 3, 2013 08:37 PM
Bill97
23
Jan 13, 2012 10:07 AM
irfreddy
30
Nov 14, 2011 07:20 PM
