Panel problems on a 1997 E150
Old Jan 30, 2003 | 09:14 AM
SMFord's Avatar
SMFord
The heater fan on my '97 F150 will only run on the High setting. Is the problem in the motor or the switch? Someone also mentioned that there may be an inline resistor that could be bad. Any help is appreciated!
Old Feb 2, 2003 | 02:59 PM
Mane's Avatar
Mane
How did you take your dash panel out i have a ford e150 and the heater switch is stuck in low and i dont know how to remove the panel and the switch is all ready ordered and i was told there were four circuits and which ever circuit breaks wont allow you to jump to the next circuit please help if you can.
Old Feb 3, 2003 | 09:17 PM
Torque1st's Avatar
Torque1st
Posting Legend
It looks as if you people are not having a whole lot of luck finding any answers here. I am moving this thread to the electrical forum where you may have better luck.
Old Feb 6, 2003 | 10:32 AM
SMFord's Avatar
SMFord
I took my pickup into a local Ford dealer and the problem is in a resistor for the heater blower. This resistor is a Ford only part and is not available at 'generic' parts stores. The part number is F4ZZ*19A706*A - about $15.00.
As far as getting the dash panel to access the fan switch - it pops right out. Get your fingernails (or other object that won't scratch the dash) behind the top of it and slowly pull it out. I did not remove the whole panel, because the right side, where the passenger air bag switch is located, did not come apart as easy. You'll have to figure that one out!
Old Feb 6, 2003 | 10:59 PM
steve83's Avatar
steve83
You can find out how to pull almost anything here.
16
Mar 5, 2014 08:57 AM
Torky
1997 - 2003 F150
Nov 26, 2002 07:20 PM
copeina
1997 - 2003 F150
Sep 18, 2002 03:14 PM
jethro
Sep 26, 2001 10:32 AM
billtruker
1997 - 2003 F150
Oct 1, 2000 12:22 AM
