I need help!! Overheating
Old May 18, 2010 | 07:14 PM
milleroutdoors's Avatar
milleroutdoors
I have an IR gun if you would like to use it.
Old May 18, 2010 | 09:06 PM
WilsonTaylor's Avatar
WilsonTaylor
I had a similar "nest" when I pulled the rad when I swapped my motor. I had not had a problem with overheating though.
Old May 19, 2010 | 12:48 AM
Bergerson's Avatar
Bergerson
I "Think" I have this whipped, I put on a new cap today, on the drive home from work i was lugging it up a long steep hill and keeping EGT's as high as possable as long as possable to recreate the problem, the temp gauge never moved off of 1/4 normal operating range.
After doing all this work and BS it looks like it was a bad cap all this time.
Old May 19, 2010 | 06:52 AM
WilsonTaylor
Glad you found your problem. Sorry that you had to do all the "diagnostic" work to find it. Just think of it as preventative maintenance
Old May 19, 2010 | 01:12 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Good to hear that you have it solved. Sorry we couldn't help you sooner. At least you have some new stuff and some good spares. These engines go a long time so eventually you'll need those parts again.
On a side note, (and this is complete speculation...), I think the caps may have a built in pop top or something similar the provides a hint there may be a problem. Sorta like the same thing you find on bottled drinks (the metal cap has a little button that pops up once the cap is unscrewed for the first time). I noticed that my original (bad) cap had some give when I pressed down on the label while the brand new cap was nice and solid. Not sure if that means anything, but I would be curious to know if you have the same thing on your end. Do you have your old cap? If so, can you try pressing down on the label and see if you have some play and then check your new cap and see if it is solid?
This might help some others who may be having a similar problem in the future.
Old May 19, 2010 | 10:12 PM
Bergerson's Avatar
Bergerson
My old bad cap has no give to it.. ??
UPDATE: After All that BS it was the FRIGGING CAP!!!
I ran the crap out of it tonight on the way home, holding EGT's up around 1200 and spiking them up to 1500 a few times just to make sure.. the temp gauge never moved... thanks for all the help guys!! now im just $600.00 poorer for a frigging $10.00 cap.
Old May 19, 2010 | 11:36 PM
Shake-N-Bake
Thanks for checking your old cap...it was just a hunch about the pop top thing.
On the bright side, your truck smokes the heck out of those tires!
Old May 20, 2010 | 01:06 AM
Visseroth's Avatar
Visseroth
It still looks like you hit a bird's nest head on!
caedo
South Dakota Chapter
Apr 30, 2014 10:45 AM
bigseadaddy
Apr 13, 2011 09:50 PM
YoungFordAddict66
18
Apr 11, 2011 10:16 PM
StanleyZ
6.4L Power Stroke Diesel
20
Jul 7, 2010 06:58 PM
Bergerson
19
Dec 23, 2008 10:11 AM
