Fuel Pump Alternatives?
ITP 5/8" Fuel Tank Pickup
I'm still unsure as to what pumps to use but I'm seriously considering just using the stock SD pumps.
Now if only I had more money to throw around.........
The other problem I have is that I have the FRx mod, if I do the fuel bowl delete then I loose my FRx unless I get new lines for that too. Oh!! so many problems. Guess I can cross that road when I come to it and just get the tank modded and work on getting the pumps in then wait for enough cash to delete the bowl and all that fun stuff, maybe I'll just leave the bowl for the heck of it.
OH SO MANY DECISIONS!!!
Guess I'll ponder on it and come up with a game plan. Then again maybe I don't need that after market filter if I just install a regulator after the pump to keep the regulator on the engine from getting to much pressure.
I'll have to get my fuel pressure gauge first before I can get all this other stuff done so I can see my fuel pressure and the pressure drop once I can do the mods, but thanks for all the ideas, sounds like it's time to do some planning.
Thanks everyone too, I still don't know what pump I want to go with but I guess I'll figure it out.
For your 2001 Ford Truck F350 Super Duty P/U 2WD 7.3L Turbo Diesel 8cyl
<INPUT id=enlargedImage value=http://contentinfo.autozone.com/znetcs/product-info/en/US/ar1/E2236/image type=hidden>
<!-- Prices page included --><!-- Start -->Price:
$151.99
<!-- End -->
AVAILABILITY:
<INPUT disabled onclick="radioSelected('list')" value=true type=radio name=/atg/commerce/order/purchase/CartModifierFormHandler.sendToStore><INPUT value=" " type=hidden name=_D:/atg/commerce/order/purchase/CartModifierFormHandler.sendToStore>
STORE PICK UP
SPECIAL ORDER
Visit your local store to special order.
<INPUT value=/autozone/catalog/parts/partsProduct.jsp?displayName=Fuel+Pump&itemId=78-0&navValue=14900078&parentId=49-0&productId=601016&fromString=&itemIdentifier=6010 16_74979_6138_&filterByKeyWord=&categoryNValue=&is SearchByPartNumber=&categoryDisplayName=FuelDelive ry&store=171&skuDescription=AirtexMaster/FuelPump&fromWhere=&searchText=&_requestid=1297248 type=hidden name=/atg/commerce/order/purchase/CartModifierFormHandler.successURL><INPUT value=" " type=hidden name=_D:/atg/commerce/order/purchase/CartModifierFormHandler.successURL> <INPUT value=/autozone/catalog/parts/partsProduct.jsp?displayName=Fuel+Pump&itemId=78-0&navValue=14900078&parentId=49-0&productId=601016&fromString=&itemIdentifier=6010 16_74979_6138_&filterByKeyWord=&categoryNValue=&is SearchByPartNumber=&categoryDisplayName=FuelDelive ry&store=171&skuDescription=AirtexMaster/FuelPump&fromWhere=&searchText=&_requestid=1297248 type=hidden name=/atg/commerce/order/purchase/CartModifierFormHandler.errorURL><INPUT value=" " type=hidden name=_D:/atg/commerce/order/purchase/CartModifierFormHandler.errorURL> <INPUT onclick="radioSelected('cart')" value=false type=radio name=/atg/commerce/order/purchase/CartModifierFormHandler.sendToStore><INPUT value=" " type=hidden name=_D:/atg/commerce/order/purchase/CartModifierFormHandler.sendToStore>
SHIP TO HOME
AVAILABLE
Ships within 2 business days.
<INPUT type=hidden name=/atg/commerce/order/purchase/CartModifierFormHandler.addItemToOrder><INPUT value=" " type=hidden name=_D:/atg/commerce/order/purchase/CartModifierFormHandler.addItemToOrder>
<TABLE id=prodspecs cellSpacing=0 cellPadding=0><COLGROUP><COL class=first-childtd><TBODY><TR><TD>Part Number:</TD><TD>E2236</TD></TR><TR><TD>Weight:</TD><TD>1.85 lbs</TD></TR><TR><TD>Warranty:</TD><TD>1 YR </TD></TR><TR><TD>Notes:</TD><TD>In line ****caution**** a fuel pump is more likely to fail if installed without a new filter, fuel pump warranty valid only if filter is replaced at the same time
</TD></TR><TR><TD>Contents:</TD><TD>Rubber sleeve, hex nut, inlet fitting, washers o-ring</TD></TR><TR><TD>Fitting Size:</TD><TD>Outlet - 5/16 in.</TD></TR><TR><TD>Fitting Type:</TD><TD>Outlet - quick connect</TD></TR><TR><TD>Gallons Per Hour:</TD><TD>35-45</TD></TR><TR><TD>Pressure Rating:</TD><TD>95-110 psi</TD></TR><TR><TD vAlign=top>Shipping Information:</TD><TD>Overnight and Two Day shipping are not available for PO Box, APO/FPO/DPO or US Territory addresses.</TD></TR></TBODY></TABLE>
Features & Benefits
Master offers in-line electric pumps for vehicle-specific and universal applications that meet or exceed OE specifications. Always replace the in-line fuel filter as a part of fuel pump service.
It out pumps every walbro and half the aftermarket ones. It can be used submerged, and inline, sucking, and booster. Has threads on both sides as well.
Ill probly get one of these for my truck. Its called the "Bosch 044"
Bosch 044 External Fuel Pump, 300 LPH! 0580254044 NEW!!: eBay Motors (item 310217113271 end time May-30-10 02:51:36 PDT)
So I'll still put a PSI switch in place to indicate a pump failure but single pump with one on stand by is the route I'll take.
I'll let you know on what I find in regards to the pumps you have recommended.
Do I need bigger fuel lines to maintain steady pressure at the regulator? I doubt I'll go any bigger than Stage-2's... I just wanna do it up right while I have it apart.
Bosch Fuel Pumps
Put the first one in the tank and the second under the floor between filters. I don't have that kinda money. I just need to make sure the pump will pump what I need and more and be able to keep up.
Lower Pressure = Higher Volume
I have a low pressure pump (4 psi) lift pump that flows twice the volume of any of these high pressure pumps.
